Hello,
Just wanted to confirm;
When HICAS removed from R32, the HICAS dash light will turn on. However, a way around it is to cut a wire from the HICAS ECU.
If this wire is cut, will the HICAS light still be visible when key is in Accesories?
Thanks
https://www.sau.com.au/forums/topic/377085-r32-hicas-indicator-on-dash/
Oh, been a while since I had a 32...
Umm... It'll show up when you put key into acc. Also it'll come on when you've got low level of power steering fluid.
I'm not sure about whether it'll come on when the key is on acc but am sure it'll come on when you've got low level of power steering fluid.
Thanks for the help :)
Could anyone confirm if the light is on during acc?
Cheers
NONE of the lights in the dash is on with ACC. They only come on when you switch to ON, and they then come on when there is a problem with the relevant function while the engine is running.
doh! I meant when key is turned to ignition and all dash lights are on before you crank the engine. Apologies
  • 1 month later...
