Hi, I'm Dan.
Recently bought MR30 Hatch, really like it. Not many around Brissy.
I want to upgrade the brakes and suspension.
Suspension will be King Lows, with struts to match (have pedders for front, some yellow things for the back)
Brakes are ok for a daily work car, but after a few heavy stops it fades pretty bad. Have had fluids flushed and changed to Nulon DOT4, seemed to make a very small difference.
The L24 is going to be turbo oneday soon (have bout all the parts, just need to lock or limit the dissy to stop it advancing)
I have read about import struts and R32 this and that. Its all too expensive for me (im on $400 a week) Plus im not the most mechanical minded, have limited tools and stuff. Still learning as I go.
Im thinking some slotted/vented disks, uprated pads (like the EBC red or green pads off ebay.uk) and stainless/braided brake lines would be an improvement?
Has anyone undertaken a 'factory' type brake upgrade like this before? I have contacted a few places but they all ask for the MR30 disk DIA, which I dont know.
Would it be better to upgrade to R31 disks and calipers? I have read previous topics but there didnt seem to be a conclusive answer.
(Also, part number for standard aus R31 pads is DB1105, but DB1085 is the equivalent part and is a commodore pad. And being a commodore pad there is a MASSIVE range of pads available)
Can also use 'RB74' but they have many reviews of ALOT of brake dust (I wash at least weekly so thats not too bad)
I have seen R31 setups go for $150, which seems pretty good.
http://wiki.r31skylineclub.com/index.php?title=Brake_Upgrades_Miscellaneous
Finally, If the R31 pads and the R30 pads are similar/same, does this mean the upgraded pads for the R31 will fit the R30 caliper?
https://www.sau.com.au/forums/topic/377134-mr30-brake-questions/
Quick note:
Aus MR30 Disks
http://www.dba.com.au/products/dba317sl $249 each
Aus R31 Disks
http://www.dba.com.au/products/DBA615SL $149 each (plus $30 shipping)
Bendix Ultimate Pads have been reccomended for the R31 calipers, at approx $130 for L & R front. (Also dont forget the
Looks like going to R31 is a better idea even based on cost of replaceing components ($200 saving just on disks)
Ebay has a few sellers that seem ok:
EBC Green Pads R31
Also note:
R31 wheel bearings part No. K1168 R31 Bearings
R30 wheel bearings part No. K1145 R30 Bearings
Both $43 posted (seems a bit much)
I am looking at picking up a set of struts this weekend to test if the components fit the R30, I will let you know what happens.
good point about the overall cost of replacement parts too. Didnt even think of that!
I was at one point looking at Commodore Caliper and 'insert unknown' deisks, just it was too much fugging around to get the right disk. Commo parts are cheap as too...
AND let me say ................... No modification is cheap if done right the first time around.
Bang for your buck ............ the VT Commodore front conversion is the best your going to get and you get a 2 spot caliper to boot, but the initial outlay can be a bit costly unless you have free access to a reasonable machine shop, or are prepared to pay to get the machining done.
There is DR, but DR30 front struts have to be sourced and new discs are nearly impossible to find and DBA have ceased production.
And you don't need to do anything, but change to good quality brake pads that are g'teed to at least 550 degrees.
D
I cant see how Commo conversion is going to be cheap as there is no info on what the actual parts required. It will have to be trial and error, then wasting money on hub coversion to suit disks which havent been proven to work!
Anyone have actual info or is it all just too hard on this forum!
u can do the s13 upgrade 4 cheap, do a search, fairly easy and cheap, you gain 4 pots and heaps of options of rotors to use, if yopu dont wanna do that try find sum dr or hr struts (100mm brake spacing) and have them modded to suit coilover, k sport do a cheap kit, didi it to a mates, works fine.
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
