Just out of curiousity where/what would you change in the tune to stop AFM cars stalling when running with a atmo bov/no bov causing flutter. I know you can tune it out as VL turbos and R31 redtop rb20dets never came with bovs and fluttered from the factory without stalling.
I imagine the cause of the stalling is where it runs very rich just after throttle off, would simply pulling all fuel from ~400rpm fix the issue? So when it stumbles it doesn't add even more fuel causing it to stall? Have any tuners looked at the stock redtop tunes to see what is different? I personally run the stoc recirc valve but I'm curious what the difference is.
One thing I have noticed is the redtop rb20s have a strange cylinder sticking out the intake that leads to nothing. This is post AFM and looks a bit like a buffer, could this be what they used to stop the stalling issues? Eg it buffers the fluctuations in pressure in the intake causing less AFM voltage fluctuation?
  • Replies 45
That would be a resonant chamber - just for noise tuning, although they can have a little influence on total power (in NA engines) by affecting the resonances in the inlet tract. I wouldn't expect any such effect upstream of a turbo however.
I would think that playing with the timing at the low rev high(er) load cells would be needed as well as fiddling with the mixtures. Kinda depends on what load cells it's actually accessing when the stall occurs though, because you wouldn't want to have to butcher the tune in those cells if they also happened to be cells that were accessed during normal operation, which is entirely possible.
Totally agreed, mainly why I mentioned the 400rpm cells as these would never really be accessed apart from when starting or the engine is stalling.
If anyone does have stock redtop rb20 maps, would you be able to look at these areas to see if there is anything stand out that might have been done for this reason?
Is this just an rb20 thing as Ive had my rb25 tuned with atmo bov (it was easier to install that way, less plumbing less fab) and I have no stalling issues, tuner did say the bov was quite good at staying closed and zero leak at the wrong times...
Got any p/n's for ECU that came with bovless vehicles? I can check maps in Nistune and post 'em here.
Apparently some BOV users accept this fact.
And still have that little shimmer of hope that a girl will hear it, strip naked, and dive into their car. (Hopefully before it coughs up a heap of black smoke and stalls)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
