Hey guys
Up for sale is a R31 skyline RB30E series I with 170,000km engine with reciepts ready for drift. Full cage has been put in all padded up, cell tank in the boot, hydrolic handbrake, pod filter, mini spool with 3.6 gears, dual rare sway bar, 1 piece tail shaft, has 5 guages (oil, water, rpm, oil pres & vaults), lowered springs, Recaro SR3 style seats, fully de tarred interior, extractors, R31 house rear wing lip (look very nice), front lip, harness seat belt (only driver side), has a new clutch put in and a little bit more that i can't remember. Car owes me about $6,000. Was built for track/drift, but never had the chance to take it once, so will be passing on this beauty to someone else. Car is Unregistered, but it can be registered by taking the cage out etc. All this car needs is either a turbo kit or a turbo engine such as RB25. Everything is set up and ready to go.
Asking price is only $3,500 slightly negotiable.
Pics will be uploaded very soon.
Located in melbourne.
Contact number is 0457 245 473 Name: PJ
Please sms/call if keen. Don't really check the internet much so your best option is contacting me.
https://www.sau.com.au/forums/topic/377169-nissan-skyline-r31-drift-ready/
Can you tell me if any work has been done on the brakes, and/or suspension?
I am interested. Just wanting to know what, if any, work has been doen to the brakes and suspension?
What part of Melbourne are you in?
Hey buddy.
Brakes are standard brakes, and it's got pedders suspension.
Apart from that, all the mods are listed at the top mate. Well worth it.
Located in the Northern Suburbs of melbourne.
I'm a girl! Sorry for any confusion. Can you tell me whether it is pedders springs and shocks? Thanks for the prompt reply.
I am looking for a better brake/suspension combo, but I can do both, as I have the parts, But if the car doesn't at least have pedders springs, it is outside of my budget, coz I will go Bilstein and GTS brake setup.
Cheers for the info.
Sorry for that. Yes, it is pedders heavy duty springs, very stiff.
Never went brake set up as it doesn't need it, otherwise you'd be flying out the windscreen.
mmm they do need it if your gonna do anything other than drift.
I am not interested in the hydraulic handbrake, how much without that setup? Bottom dollar cash, and I will come and pick it up this weekend.
Well you do realise the hydrolic handbrake only costs $200 with lines. So there isn't much i can deduct in the price. Mind you it's second hand now, so id be selling the hydrolic handbrake cheaper then $200. $3,000 is a steal.
How much did you think they sell for? I am negotiable on the price, you can buy the car as is, but at the moment you don't really seem genuine asking all these questions over forums when I have actually left a phone number to be contacted on.
Think what you like about whether I am genuine.
I was asking genuine questions in a public forum. I can't see what's wrong with that. It's where you have advertised it. It alos helps other people who may be looking at the thread.
No offence meant here either BTW. I really was just trying to get some extra info on the car.
I am still interested, but it's a bit out of my price range.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
