what is a guy to do if he wants to take out his buddies to a clean place and be served his dinner by a sexy hot waitress in short shorts and a shirt 2 sizes too small?
Get you buddies to come over and have your girlfriend cook for 'em in a skimpy outfit?
I don't know, there probably ARE Hooters type places in Japan... it's just that you have to be Yakuza (or a cashed up salaryman) to gain entry.
You're not looking hard enough :D
In the late 80s there was a fad where cafes had mirrored floors and girls with no panties serving! sc3w hooters!
these sort of things aren't franchised like they may be in the US, but they can be found in any major city. But like rezz says, you might not want to go there. Another key reason is that these places cater for salarymen with business accounts - not gaijin surviving on a basic salary.
I have a friend who went to a post-enkai snack bar and was told by a co-worker (superior) - go on, take one of them home, any one you like (of course he did). Again - sr3w hooters!
This is place is a men's paradise (and, admitedly, a women's hell at times). I'll say it again - if I was a single man, I'd never leave :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
