yep... stock motor and low mounts.
but 400rwkw is so like 2006 :whistling:
ha ha ha\
Honstly... 300rwkw is more than enough for anything in Tas.
That depends on if you like to overtake with wheelspin :thumbsup:
Mine WAS a nice car to drive back in the day (2005)with a 300rwkw RB25 but am looking forward to 500+ with the auto
Made 580RW KW at GT Garages first dyno comp a while back.
Slowly getting the old gtr back on the road again here are some parts ive collected over a bit of time
Direct twin plate clutch Caple motorsport plenum with 102 mm throttle body 290 11.5 cams with oversize supertech valves and double valve springs bRAND NEW NISSAN HEAD Ross metal jacket with new crank and cam sensors does away with std nissan CAS also brackets and pulleys for dry sump set up
50mm pro gate 2000 fuel Nitto DBS headgasket 10.5 to 1 comp JE pistons 2000cc injector dynamics injectors and rail kit 60 psi EBOOST 2 with 4 port solinoid Got coming A GT55 turbo Kernen manifold
thats mental
  • 1 year later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
