Stock Rb25 Cam Gears
By Akshunhiro · Posted
Hey all, ordered this recently for my M35 but completely forgot there's a major difference between RWD and 4WD front crossmembers so it doesn't fit Not confirmed but I suspect it may fit RWD M35 and G35 Z33 350Z/V35 Under engine bash plate This is for the bash plate only, no bumper retainer Make an offer Pickup only, Brisbane inner-west Cheers, JB -
Yeah do that, it’s only 120kAUD!!! You should have that sitting in the ashtray
If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car. I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off. -
Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ). Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah. Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
