A question, for those of you who have been defected in the ACT, and then made changes to pass the defect and gone back to how the car was before, eg rims that are too big, or car slightly too low ect.
Have you been re-defected or once it is fixed and solved it generally all been fine.
Also, when and how where you defected..
The whole story:
My girl got a new car, had a few issues, we fixed them for rego, and get it passed at a local repair shop. Then the gov decides to audit the inspection place, and gets us to bring the car in to dickson, which was mostly fixed from before. They defect it on some of the same stuff and a bunch of new stuff, mainly the fact the track on the front wheels is out (20mm less than should be), and the front tires scrub the inside on full lock, even though the rolling diameter is fine. And the eyebrow height of the car, as in centre of the wheel to the guard (the car clears the 100mm off the ground no issues).
This is a pain cos the suspension is totally new pedders sports suspension, which barely lowers the car at all, and when the first check was done, we took out the stupidly low superlow king springs and had stock ones in, so she could save to get the new ones which are now installed. And they actually said the back was right on the limit with the stock ones though.
*There are a few other things that they knocked, but they were easy fixes that i've done, these are the problem ones that are f*n expensive to sort, esp that we just bought the NEW suspension!!*
Just curious how likely she is to get stung again if some of the changes are changed back afterwards? But also if there is a way to get the different eye brow height complied? Cos the wheels are inside the guards and dont scrub (except the fronts on full lock). We may need to look for new rims, and they also need new tires cos are 86 not 84 for the load baring capacity for some unknown reason!
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
