Therre was a ca/sr ecu that changed between sequential and batch, but considering the rb20 ecu only has 2 injector drivers it is batch only. No sure about ignition tho.
Pretty sure ignition is because you have 6 ignitors, if it was batch they would save money and use 2 or 3.
  • Replies 63
Not enough memory I guess the extra timing calculations would require alot more code CPU used has limited outputs
Im actually a programmer and one of my job was writing software for old processors, namely the same cpu used in these early boards. The code for writing to 2 outputs vs 6 and doing sequential vs batch is basically identical, the cpu still runs fast enough to process that many events. I can't see the CPU being the limiting factor, would have been something else but f**ked if I know what.
Funny enough I'm a programmer aswell yeah there wouldn't be a heap of extra code there is a bit of room available then again I've never worked on these chips they are probably faster than I give them credit for
You guys dont have a clue.
You realise in going to the haltech you will be batch firing injectors and coils! The std ECU is fully sequential on both. It will do everything about 100times better than the haltech ever will.
http://www.fueltech....pdfs/HalE6K.pdf
8 injector drivers as standard equipment
There is a reason haltech doesn't support the earlier ECU's anymore is beacuse they are shit.
You dont think it has something to do with the fact that the e6k is near on 10 yrs old now and used old technology, how many companies do you know of that keep producing things for 10yr old hardware when there goal is to always develop newer technology? Edited by W0rp3D
A bunch of programmers here haha.
Not a lot of additional code would be required to implement fully sequential injection/ignition. You basically just need slightly more sophisticated CAS decoder subroutine and cylinder counter and assign calculated outputs to different output ports based on that counter (using it as either input variable or index on inj/ign subroutine call). It's just one more routine and a couple of additional RAM values.
Those old CPU's are not very fast, but fast enough to handle engine management (some of early factory ECU's have hardware cap of 8000 rpm - been tested by Nistune developers, don't remember if RB20 is one of them). The only reason for not using fully sequential management I can think of is CPU may not have enough output ports.
Multiplexing can be a bit tricky in real-time applications like engine management. Requires some cleverly arranged synchronization.
On the other hand, it depends on how exactly CAS/load-calc-output data flow is implemented.
By the way I'm pretty sure I've read somewhere that R32 RB26 uses fully sequential management.
Neo motors use 16-bit processor, different family and higher performance. R34's use Mitsubishi 7700 processors, earlier Skyline ECUs use some kind of Motorola 8-bit clone manufactured by JECS, if I'm not mistaken.
EDIT: I mean I'm agreeing with you :) I'm just explaining why full seq. mode is easier for later ECUs
Edited by Legionnaire
Yep, much newer processor with more features.
Not necessarily so. The CPU itself may be the same/similar, but its peripheral devices can be very different - it's an ECU architecture thing. E.g. RB26 ECU may incorporate multiplexing/decoding logic you were talking about.
Sure, it is all speculation only. The best way to do it is to open ECU case and take a look what's in there. And assembly code would be handy also.
But I seriously think they are all sequential, otherwise they would use crank sync trigger instead of CAS.
By the way 16-bit processors are seriously faster than 8-bit in this particular case because all AFM values and load calculations use 16-bit arithmetic.
  • 4 weeks later...
Hey I was wondering what ecu would be better for my setup mods are
Td06h-20g 8cm housing
550 injectors
3 inch exhaust
35 mm turbosmart external wastegate 17 psi
Stainless high mount
32 gtr cooler
I know nistune will be cheaper but lets put price aside on this one
so which one did you go with?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
