Mas 04 Pictures
slayer_1971
 Share
i brought the camera on saturday but thought the dyno was broke so didnt take any of the cars on the dyno plus i was pretty much stationed at the stand for both days without leaving much cause everyone ran off when they came on
  • Replies 103
adz might have been.... he had his video camera didnt he?
i hope someone got the flame!
last year i never got to see any footage of leewahs flame even tho someone had footage
did and sau guys take video of cars on the dyno?
i think i saw nackers with a video camera near the stand
i took some videos on my digicam... i took some of your cars run and a few others... not the best quality but ok... i'll post it when i put the photo's on my pc...
Guest INASNT
My friend took video through his SLR camera of dave from the side near the roller door and niges run from the front. I gott get em off him this week.
Has any1 got pics from the bikini contest???
i don't think so... everyone wanted to see james's car blow fire... Al should have some pics of the miss autosalon contest though...
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
