I've been in the same boat lately too. Had to make time just to play mp3 but it was worth it.
The story is awesome, and mixed with the great gameplay and soundtrack. It's just an all round cool game.
  • 3 weeks later...
hilarious!!
Am having probs with Mr Payne at the moment. I thought it was gfx card related but not the case.
My other PC games are working fine. I went to play, patch installed, and now it just hangs on the very opening black and white credit screen. Crashes completely!!??
any of you guys had this? am running a 5870 and the display driver stopped working for 5 secs then restarted itself all ok. As mentioned everything else is fine, just not max payne...
hilarious!!
I've got it on ps3.
But checked out your issue and seems to be common across the community with fixes available.
Rockstar should have an official fix for this.
EDIT - http://m.rockstargames.com/maxpayne3/news/article/max-payne-3-pc-new-patch-for-commonly-reported-issues.html
Ahh spewin Eeleye, got excited but gave most of the things on the page a go (eg UAC control panel, administrator, registry) but no luck. I might just need to be patient and wait for next patch.
On a lighter note i bought Batman Arkham city for $21 at JB HiFi so just starting it now, takes up a sh*T load of gfx processing. My 5870 used to max out pretty much every game i own, looks like batman has the one up on this one.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
