Well I pulled off my old intake to measure up a newer new one. Attached are the pics below. The bends are two roughly 45 degree bends with some angling done to face the side of the car. Since these are two 45 degree straight cuts, will this pose an issue? I see some people using curvy bends while mine is a sharper bend. Ive attached some pics so you can see how it looks. It was awesome too, the pringles container is exactly 3" awesome piece of tube to have to measure up some piping, easy to cut, tape together and measure!
Anyway, after I measured it and put the car back together with the old pipe, 3 times today my car switch off when clutching in after coming on boost. To ensure I am on the right page, is this an indication of boost leak or a vacuum leak? If it was a leak under boost, I would be blowing smoke because I am not breathing enough air. But it stalls after clutching in... I do not run an atmo BOV and my current intake pipe never had any recirc issues where the BOV line affected the AFM(its facing the turbo on the return and is after a bend. I haven't pulled it apart again but everything looks tight. The car was not stalling before.... It was also not lean popping. Now it appears when I am on idle and try to hold say 2500rpm in neutral, it will splutter and pop. This is NOT evident when driving but when I clutch in and the engine revs down to idle it splutters. Could all these problems be related to a vacuum leak? I didn't have time to check it out as I just got back from work.
I hope my fuel pump isn't failing again. I am sick of going into that damn tank. I can hear it priming and under full boost the car drives brilliantly. It seems just under tiny tiny load(like the throttle JUST touched) when cruising, and more evident when in neutral.
In the pictures, the metal bottom of the pringles tube is facing the turbo.
  • Replies 122
What fuel pump did u fit again? Wasnt it a second hand gtr pump?
Maybe its starting to fail, it is a bit weird that its only happening since u made a new intake pipe.
Try earthing the fuel pump in the boot so that its not a variable earth. This may fix the lean pop issue at idle.
I see nothing wrong with the intake design itself as i run one with a 90 degree and 45 degree bend with no problem.
Why didnt you just put a decent new pump rathet then mucking around with 2nd hanf parts that are just as old.
I needed a pump asap. I ordered a 040 new but it took its time to come so I found a wrecker selling the gtr pump on saturday. I needed the car asap. I'll ground it today and see how she goes. I'll then adjust my intake setup double check for leaks then test the stalling. Luckily I'm on last quarter fuel.
I'll be fitting the fuel pump in tonight if I can. Grounding this pump didn't fix it and it seems I'm stalling after boost and clutching in. I've even blanked off my bov incase I was having recirc issues and no luck. Also noticed my fuel cap was so pressurised it was hissing when closed... How do you pin point a intake leak?
the stock intake piping is accordian style to avoid reversion over the AFM hotwire signal
you might find using prefectly curved pipework with a smooth edge introduces reversion which makes the AFM tell the ECU you have whacko air flow meter load, thus it stalls
this is common when people change their intake pipe to nice smooth shiny finish pipework (like what you are doing)
I have never had a customer complain of reversion with one of my intakes, as long as the bov points towards the compressor the two bends should stop any further reversion. I do use lobster bends though which may help a little.
Bullshit.
Those pipes are smooth but they do have some crazy angel on the return pipes., my old pipe on my old car just wasn't working. this pipe was fine. it probably isn't reversion because I did disable the bov. It seems like a leak somewhere. Anyhow I am installing a 040 now. Lets see how we go.
I think this is the key reason for reversion.
Woman driving lol.
Sarge are you off work today? I dont mind taking a look for you, am in Penshurst.
This would be very appreciated. Are you free this sunday? I can bring it to you then as I need help because I just fitted the new fuel pump and no luck. Issue seems evident (the popping issue) after the engine is above 45c. new spark plugs go in tomorrow as well as examining more vacuum lines
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
