Hi I have just fitted set of BC V1 Coilovers,bought from JustJap, excellent to deal with,to my R34GTT. I selected 6kg front and 4 kg rear springs and have set them at 15 front and 17 rear from hardest,old fart settings.
Best money I have spent in a while,I can highly recommend them
Cheers
Steve
https://www.sau.com.au/forums/topic/377351-bc-coilovers/
Cheers
Steve
Yeh mate! they are good. i have them in my gtr! highly recommended!!
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6018377
Amen, have a set of 8/6 in my R33 GTST.
loving it. Firm and responsive enough to get really rowdy with confidence, soft enough to drive in every day and not wonder if it would have been better going for other coilovers/ spring settings.
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6018568
Cheers
Steve
Hi mate can you give a more in depth review, eg how the car rides over train tracks, bumps in our great smooth roads we have, how hard it is overall (i know it depends in settings/personal preference), is the car flat around corners (no body roll), better or more precise handling around corners.
I'm getting new suspension soon so would like your thoughts. on the suspension you got. Thanks.
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6019328
I've had the coilovers since about April with the 8kg/6kg setup. Even whilst all set to soft I find it a pretty harsh ride... but the handling is precise and corners pretty flat. Most people seem to be happy with the ride but on a bumpy road you're going to feel it... The coilovers are best suited to a track rather than the street that's the feeling I get. If you can I'd definitely get slightly softer spring rates.
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6020428
  Quote
I just fitted BR series to an R33gtst last week, went for the 8/6 spring rate on the advice of Justjap (was going to go 6/4). Roads are pretty bumpy up here and 8/6 is fine, not radically different to stock. 6/4 would have been too soft IMO. Have dampers set 10 clicks from soft, so 1/3 of full firmness. Also have whiteline swaybars front and rear, might just be me but I still find it has a bit of body roll - eg my ST185 GT4 has similar setup, Tein superstreets and whiteline swaybars, and that has wayyy less body roll, very flat thru corners, so was a little disappointed with the R33 in that regard. But for $1300 delivered the bc's seem great value, ride is probably perfect for street, as in firm but not too harsh. Would need firmer for track, I would imagine..
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6022154
For $1,300 they are great value. I fitted them on my R34 Skyline GTT and here a shot of it on track, you can see there is not much bodyroll at all. Not harsh for the road either.
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6030129
yeah im on the 8/6 diet n its gold. In perth our roads are prety flat so not a problem. If you were in an area with shit roads maybe go the 6/4, but otherwise the 8/6 are the biz.
prior to that i had 9/10 (thats right, 10 on the rear) n that shit was haaaaaaaaard.:yucky:
Slid like a champion tho n you could draw lines like a draughtsman...
I suppose thats why they were call HKS Hyper D's (drift) tho...
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6036538
Hi Keep in mind my Boy Racing days are over. The BC's replaced Bilsteins and Kings springs,what a difference, the BC's absorb bumps better and being adjustable you can set them to your mood or driving style, ride height is easily adjusted,less suspension noise and lighter. If you have an R34 I would also get the adjuster extentions for the rear,save you taking the seat out to adjust.
Cheers
Steve
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6039859
  On 02/10/2011 at 11:30 AM, blonk20 said:
fitted my bc's about 2 weeks ago pretty damm happy with them on sh***y gold coast roads not to much firmer that standard imo well woth the investment, wet for br's though
what spring rates and damping setting you doing this on?
https://www.sau.com.au/forums/topic/377351-bc-coilovers/#findComment-6043423
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
