I'm 188cm and 80kg, at a guess I'm below 10% BF and fairly thin framed. To give you an idea of that, I was 62kg at the same height.
I do a two day split routine, it gets repeated again later in the week, so four sessions per week. I could probably get away with two sessions per week, but I love the extra stamina of repeating the split and there is plenty of rest to allow this. At 6 sets of 10 reps per exercise, they take just over an hour each.
First day is predominantly push (Monday/Thursday), which includes flat bench, close grip lat pulldown, incline bench, tri pushdown, woodchops and situps.
Second day is predominantly pull (Tuesday/Friday), which includes behind neck shoulder press, seated row, decline cable crossovers, wide grip lat pulldown, SL deadlifts, squats and bi curls.
I don't calorie count. I eat what I want when I want (chocolate on a daily basis, for example), but live predominatly off bread, pasta, meat, cereal and water. I'm always hungry and I stuff my face every hour of the day just to fuel my workouts, they demand that much. If I skip a meal my pants don't fit me and fat people who don't exercise have been telling me for 10 years that one day my metabolism is going to fail me - I'm still waiting.
My workout is much "simpler" than yours, yet it probably works more muscles in the body. For someone trying to bulk up I'd simplify my workout even more (get rid of woodchops, situps etc.).
/lifestory
My routine that I follow from now on is composed of a push day, pull day and leg day. SInce smashing my legs, my weight has gone up at a staggering weight i.e. 87kg to 94kg and with little to know bodyfat. Legs is my fav bodypart to train :D
Day 1: Chest, triceps & shoulders
Day 2: back & biceps
Day 3: Legs
Day 4: Rest
Day 5: Chest, triceps & shoulders
Day 6: Back & Biceps
Day 7: Legs
At the end of the day, you just gonna have to listen to your body and see if you're getting results in the gym over a prolonged period.
35
5'10" (I guess)
92-93kg
bodyfat - ?? under 20% over 10% (I can still see my wang when I look down and can tie my own shoe laces)
Monday
Squat - 3 x 5 or 3 x 3
Front squat - 3 x 8 or 3 x 5
Tuesday
Flat Bench - 3 x 5 or 3 x 3 or 3 x 15
Inc Bench - 3 x 5 or 3 x 8-10
Wednesday
Rest
Thursday
Deadlift - 3 x 5 or 3 x 3
SLDL - 3 x 6 (light weight with 3 second pause at full stretch)
BB row - 3 x 10
or
chins - 3 x 5-8
or
Inverted rows - 3 x 15
Friday
Flat and Incline Bench - same as Tuesday but if I did heavy session one day, I do lighter on this day
Sat and Sun = Rest
repeat next week.
sometimes follow my work sets with singles with increasing weight till failure to see where I am in terms of 1rm progress.
Didnt get to the gym last night, had a late meeting and oztag. Last weeks workout looked like this:
Shoulders:
Shoulder Press:
20kg x 10 reps
30kg x 10 reps
30 kg x 10 reps
Dumbbell Arnold Press: Really noticed my shoulder start to burn on this so I had to be real careful.
10kg x 10 reps
10kg x 10 reps
10kg x 8 reps
Dumbbell Lateral Raise:
7kg x 10 reps
7kg x 10 reps
8kg x 8 reps
Cable Front Raise:
10kg x 10 reps
10kg x 10 reps
10kg x 10 reps
Cable Rotator Cuff:
10kg x 10 reps
10kg x 10 reps
10 kg x 10 reps
Bent Over Delt Raise:
5kg x 10 reps
5kg x 10 reps
7.5kg x 8 reps
Had I made it last night, would have been the same workout only with 4 sets instead of 3.
Lol i'm sorry dude but this is a pretty poorly designed shoulder workout. Simple compound workout bro-science to the side, if you're gonna isolate the three heads, at least do it right. Cable front raises for instance, says it all :no: . Your anterior (front) delts get worked an absolute ass-load with chest exercises, so to even think about doing front raises just completely gives you a program that is push movement dominant. Front raises are possibly the biggest wank exercise around when working with a well balanced program.
Why the hell are you doing shoulder press, and then Arnold Presses (which btw work the muscles no different if you know your anatomy)???
This is 2 front delt exercises, then front raises makes that 3. I see 1 lateral and 1 rear delt exercise in this program :huh: ... general rule of thumb is to achieve BALANCE.
For example, do:
DB Shoulder Press
Standing Lateral Raises
Seated Rear Delt Fly/Pull
DB Alternating Upright Row
Standing Cable Rear Delt Crossover
Variation of Shrug (bit of a wank too really)
IF you wanna work on a Bodybuilding (isolation) type program.. Shoulder days are for lateral and posterior delt development, not standing in the mirror with your mate doing front raises and multiple presses.
/lifestory
YOU DA FAT-ASS
  • 4 weeks later...
Alrighty, my spotter is going away for awhile, so I am going back to a simpler routine which I know works.
I (think) have harped on about a Tri Phase routine that I gave ago awhile ago and saw some real good gains, possibly noob gains but gains none the less.
Routine is simple. Three phases designed to his your muscles in different ways. Link to all the nitty and gritty info is http://www.scivationbooks.com/books/TriPhaseVol2.pdf otherwise workouts are below.
9 week routine. Each phase is 3 weeks each.
Phase 1 - Volume:
The goal of Phase 1 is to increase the volume (number of sets) each week. In
addition to adding sets each week, you should always strive to lift a greater load each
workout.
• Week 1 = 3 sets per exercise.
• Week 2 = 4 sets per exercise.
• Week 3 = 5 sets per exercise.
Rest time = 90 seconds between sets
Back+Traps
Deadlift 3-5 X 6-10
Pull-Up 3-5 X 6-10
Bent Over Row 3-5 X 6-10
BB Shrug 3-5 X 6-10
DB Shrug 3-5 X 6-10
Chest+Shoulder
Bench Press 3-5 X 6-10
Incline DB Press 3-5 X 6-10
Dips 3-5 X 6-10
Military or DB Press 3-5 X 6-10
DB Side Lateral 3-5 X 6-10
Legs
Squats 3-5 X 6-10
Stiff Leg Deadlift 3-5 X 6-10
Leg Extension 3-5 X 6-10
Leg Curl 3-5 X 6-10
Lunges 3-5 X 6-10
Arms+Calves
BB Curl 3-5 X 6-10
Close Grip Bench 3-5 X 6-10
Skull Crusher 3-5 X 6-10
DB Curl 3-5 X 6-10
Standing Calf Raise 3-5 X 6-10
Seated Calf Raise 3-5 X 6-10
Phase 2—Intensity
The Goal of Phase 2 is to lift a near maximal load for low reps. There will be no
changes in the number of sets you complete, just the load you lift.
• Week 1 = 6-RM
• Week 2 = 4-RM
• Week 3 = 2-RM
Rest time = 2-3 minutes between sets.
Upper Body A:
Bench Press
Bent Over Row
Military Press
Barbell Shrug
Close Grip Bench
Barbell Curl
Lower Body A:
Squats
Deadlifts
Seated Calf Raise
Upper Body B:
Incline Dumbell Press
Pull Up
DB Shoulder Press
Skull crusher
DB Curl
Lower Body B:
Deadlift
Leg Press
Standing Calf Raises
Phase 3—Frequency
The goal of Phase 3 is to hit each muscle more frequently than Phase 1 & 2.
Each workout uses different exercises and different rep ranges, though the same exercises
can be used for each workout if one prefers. The goal is to do two sets of an exercise for
each muscle group. Here is an example of how this workout could be set up:
Workout A 4-6 Reps 2min Rest:
Squats
Deadlift
Calf Raises
Bench Press
Bent Over Row
Military Press
Barbell Shrug
Close Grip Bench
Barbell Curl
Workout B 6-10 reps 90sec rest:
Leg Press
Leg Curl
Calf Raises
Incline Press
Pull Ups
DB Side Lateral
DB Shrug
Skull Crusher
DB Curl
Workout C 10-12 reps 30sec rest:
Leg Extension
Leg Curl
Calf Raises
Dips
Seated Cable Row
Cable Lateral
low pulley high row
Tricep Pushdown
Cable Curl
Then you rinse and repeat.
That's a simplified workout? Dude...take it back to the basics. Ditch this article shit until you're at a serious plateau and have the foundations to make it work. 5-6 compound exercises, 5-6 sets of each, repeat the workout a few times a week, eat and sleep a lot - winning much?
so how effective was it in the past?
going by that ,what do you expect in 9 weeks time?
How much weight I actually gained is debatable as far as lean mass goes. After the full cycle my measurements all grew by about an inch each. From the time that I started and finished, I went from 66kg to about 70-72kg.
I dont think I will see that type of improvement again, because my diet hasnt increased that much as far as calories go. My goal at the end of this year is 75kg. I doubt i'd reach that in 9 weeks, but I am going back to something that I know has worked. After I finished cycle most people commented about how much bigger I had gotten, except dad.... his comments were "still a little twig"
Birds, I don't mind this cycle, it hurts, its a challenge, I get to do a little bit of every type of training and it keeps me entertained and focused. Alot of what you said, is what makes up this workout. To be honest If I was to modify this, I'd drop the frequency phase and increase Volume and Intensity by 3 weeks.
Your dad sounds old skool cool.
everyone else sounds like a bunch of "everyones a winner for participating" faggots.
I always wish someone had told me that I was wasting my time with shit I found in articles or mens health mags when I was in my early 20s.
but now with everything being available so easily and a good trend of people going back to basics (and your post up there is not a basic or simple program), I just don't understand why some people insist on wasting time over and over again.
I'd like to blame others taking after me at my gym, because the racks were always empty before I started deads/squats and now, a few months later, I struggle to get on them...but I think that's just a shitty, shitty coincidence...and more likely the result of a mass information spread across the internet for the last year or so, that has resulted in big muscle building techniques becoming more mainstream, over the usual "5kg dumbell fly" shit from personal trainers.
However...this has also started a trend of idiocy where some personal trainers think that deadlifts and bent over rows are a good idea for a 100kg 60 year old woman. Some have no idea how to customise a workout and instead put the same person, regardless of demographic, through the exact same workout they give everyone else.
Man I hate commercial gym PTs.
  • 3 months later...
so been training a bit lately, but diet has been a bit funky which is stopping any weight gains. I'll be going to the doctor concerning this as I am having a couple issues which i wont divulge into...
anyway here to ask a question.
I struggle in my upper body lifts, noticeably the bench and my pull ups (wide overhand grip). Also I only barbell curl round 25-30kg for 8 to 10 reps. I was thinking about dropping the curls and doing some close grip chinups to try and help improve my upper body strength. Anyone have any thoughts or opinion? My workout is as above and done with a spotter.
Cheers,
I love pull ups... I could barely do 3 when I started back in the gym... so to get better at them I would just do a few whenever I walked past a pull up bar... I mixed up my grips, underhand / overhand / wide / narrow
your fairly light so you should kill it on pull ups... there is a technique to them though... you need to concentrate on the first motion by pulling your shoulder blades back and down, getting tension in your back first... most people try to pull with their arms... the arm shouldn't really come into it until the second half of the motion... think about pulling your elbows back, down and in towards your body... lastly try and lean back a bit as you come up and bring your chest up to the bar rather than your chin... this will recruit your lats better
I curl every now and then at the end of a session... I'm very average at them but I can do 8-10 pull ups with 20kg hanging off a belt no worries... I can also row very heavy no problem so my lack of curl strenght isn't holding me back in those areas
I've never seen a guy with a big back and tiny arms;)
cheers for the technique tip ill try to concentrate on it when i do them next.
My arms are in proportion so I am not concerned about that, was just thinking of different ways to increase my upper body strength.
he was asking about increasing upper body strength, not getting bigger arms... curls for arm size, pull ups for a stronger upper body... you won't get better at pull ups by doing curls but you might get bigger arms by doing pull ups
but I agree, why not do both... just do the pull ups first :)
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
