Ants, I know what you're saying bruv. My point was more that old mate said he can't wait until his metabolism slows down so he can gain weight...but it will be he wrong kind of weight. He can put on muscle instead and look a hundred times better and not be a 50kg rake.
Similarly to Dan, when I left school I was 62kg at 188cm, which is probably about as skinny as ZRBE is at his height. Now at 80kg, no one calls me skinny anymore and I didn't put on any fat to get there :)
ZRBE, compound movements are exercises that work more than one muscle/joint at the same time. The big three powerlifting movements, squats/deadlifts/bench are compounds. As are rows and pull-ups etc. But those big three will put on more muscle mass and build strength quicker than any other exercise particularly for a beginner. Do those properly and you will have no problem gaining weight or eating more.
say what?!
Sweet as. Cheers for that man. :)
Well after a game of oztag tonight where I wasn't even good for a half I have decided I need to do more to look after my cardiovascular fitness.
Any cardio work in the gym before or after weight training will not happen. Not even worth mentioning.
My options are:
1. Crossfit
2. MMA at a decent gym
3. Cardio in the morning before work
Option 1 & 2 would basically mean no more actual gym work due to time constraints. 3 means getting up earlier and not being lazy. But I have no idea what type of cardio to do, jogging does not appeal to me nor does bike riding, I would have to do HIIT training but dont know where to start.
Thoughts and opinions?
None.
Weights you can do for 3x8 or 3x10.
Done explosively.
60 secs between sets.
Focus on compound movements.
Plenty of cardio.
If you're not puffed the weight is too light or you're not moving fast enough.
Alternatively, do two exercises at one time and switch back and forth set for set. 60secs rest after 1 set of each movement.
Or various alternatives of the above.
Edited by ActionDan
MMA would be a step above compound weights I'd say. Sparring is full body recruitment, huge tax on the respiratory systems.
I didn't do MMA but I did do some freestyle martial arts back in the day, nowhere near as hard a work as grappling though, and I agree it's a different type of fitness.
yea the MMA was hard, especially when I was fighting.
I am thinking about just running in the morning, least i can get the dog out with me. Pitty the baseball field locks all of its gates, cant get in and just let her off the lead and me do some sprints
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
