Hi, parting out from my s2 r33 gtst, all parts are in excellent condition. avc-r and op6 turbo are still on the car until sold
Apexi AVC-R Boost Controller $500
Apexi Power FC ECR33 (standard rb25det map loaded) $1200
Stock R33 Wheels 16x6.5 with 205/55/16 Tyres $200
R34 OP6 Highflow Turbo (see attached receipt) $1000
K&N Pod Filter with Adaptor direct fit to Nissan AFM $50
r33 series 2 ABS pump (without relays) $100
PM for Mobile Number
Thanks
Matt
Photos....
Edited by matt lopez
https://www.sau.com.au/forums/topic/377364-ecr33-power-fc-avc-r-op6-turbo-more/
MASSIVE BUMP !!!!
OP6 High flow Turbo back up for sale ! ... not removing from the car untill sold !
Power FC price dropped to 1000 posted ono.
Apexi AVC-r price dropped to 450 posted, this is less than 1 year old.
everything else still for sale
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
