Yeah that is the one. His driving was brilliant, his dress sense - notsomuch.
it was the early 90's... I'm sure most of us wouldn't post up what we looked like back then so I think we can give him a pass on the wardrobe
I'd wear a farkin tutu if I could drive like him
  • Replies 68
Posted Images
he is a great drive but not sure I'm down with the no helemet and thongs!
best bit of a vid is how he parts the gaggle of japanese reporters standing in front of it like moses parting the red sea!
how did we go from an underpowered road car with sublime handling setup by one of the most famous F1 drivers ever... to an overpowered yank boat engine with $5 of scrap metal bolted around it and no brakes!?
actually f*ck that, what I really want to know is why can't I get my hands on either one at a reasonable price in Australia!
V-Tec is one of the greatest abominations ever inflected on the motoring public. All that noise and revs to go nowhere pretty quickly :( Especially when a single spinning NSX leaves the pits and some Brazilian cant even slot gears in it :( Best give them a flappy gearbox so hacks who cant shift can still pretend to be able to drive.
Hell, at 1.00min mark he is so late getting back on the throttle because he has ham fisted it up on corner entry, mid corner that he cant get back on the loud pedal until the exit. Imagine if he lived to 2010, he would be perfect for an R35 GTR :)
I actually really like the 3.2L 6spd NSXs but its Friday arvo and want to rant a little
you need a jealousy font, would make it easier for me as I wouldn't have to read all the rubbish you posted :nyaanyaa:
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
