need your help fellas!
Looking to purchase a polisher, deciding between the GEX125 AC Pro and 150T. i know the 150 has a polisher setting, but between the two models the specs looks around the same. i was thinking the 125 would be better for the tighter spaces when polishing.
What are your guys opinions?
Thanks in advance!
https://www.sau.com.au/forums/topic/377405-bosch-gex125-vs-gex150t/
bit pricey though, i special ordered mine through bunnings - showed them the price etc for it off sydneytools and they beat it by 10% .. thats the best deal I could get it for!
I dont use any backing plate :) the FI pads fits mine just right
Yeap, as long as you mask up the rubbers well i managed to do everywhere. most machines are too big for everywhere really and you still need to give some spots a good hand polish
If you are looking for a Random Orbital that has interchangeable backing plates and more power that the GEX150T but costs $229 you might want to look at the Concours 900 Polisher at Waxit Car Care.
You can also find a range of kits to go with the Concours 900 Polisher HERE.
that actually looks pretty cool i want to try but no point having two RO's!
  • 1 month later...
I bought the 125 and then realised that it was no where near as effective at the 150T as the 150T has both the forced rotation mode (which is what you want) and random orbit. Went out and bought the 150T, as stated before Final Inspection highly recommend this unit, and it makes a big difference having a unit that can do forced rotation. I had to have the 125 held lightly against the cars surface otherwise it would bog down and just vibrate on one spot.
having struggled with an old Bosch RO only and then upgrading to a 150T, forced rotation is DEFINITELY the way to go.
a few friends have gone to Rotaries and didn't find them as scary as they thought. Obviously need to be more careful, but they said they're soo much quicker again of their prev units (Rotex jobbies $$$) - depends how serious you think your hobby is going to get :D
scr34min order it from bunnings, if you show them the price of it from sydneytools bunnings will beat it by 10% .. :D
thats what i did
also im in perth as well ... with a gex150T + pads + polishes sitting around ..
i do need to order the heavy cutting pad/polish still though
ive only got medium and extra fine ones atm
if you need any help or anything let me know :)
i have exams real soon but after that I should be quite free ...
^ i got mine for about 350 ..
no pads though
but from melb you'd have to pay delivery and whatnot ...
about the same really hahah
if you go down the bunnings route
http://sydneytools.com.au/shopexd.asp?id=1243&bc=no
show them that :)
oh yeah, i remember paying around $360 now that i think about it....
but still, $50 worth of pads in there, plus whatever was postage on them.
but yeah, probably the best deal for Melbourne ppl
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
