ok guys iv had tryed lookn but :pirate:
i have a rb25 neo 6 would it be worth getting some RB26 gtr injectors to replace the std ones i have or waste of time ..???
any help on this would be nice is there much flow diff between the 2 ?
or bettor off just getting after market ones
my mods are ..
fmic / hks-gtrs turbo. split fire coil packs . gtr fuel pump .. and next week a vipec v44 ecu system
if i was to go after market wats a good size 700 cc? i have no idear about squirts :domokun:
cheers
https://www.sau.com.au/forums/topic/377426-rb25-injectors-upgrade/
my mods are ..
cheers
RB26 injectors won't fit the 25 Neo if you're using the standard plenum and rail. There's not a lot of straight-swap injectors on the market for Neo's unfortunately. I ended up going with Power Enterprise because they were one of the only direct fits I could find. Looking back, I should have gone bigger than the 650's. Though something around that size should be plenty big enough for your application unless you're planning on going E85 at any stage.
Wouldn't Nismo make some drop in injectors for the Neo motor? If so I'm sure you can find a set of 555cc Nismo's which will do nicely. The Standard is what, 370cc, the GTR is 440cc(I think). If you're maxing your injectors and you don't really plan to upgrade in the future then 555cc injectors should be sweet. I got Nismo 740cc injectors and with a SS2 hypergear turbo, I rarely see more than 50% duty cycle on them even on full boot.
Ask simon s14 on here- he got siemens deka 700cc or something from ebay usa for real cheap- u need top feed high impedence injectors- i think u will have to add a coupla washers to lift up ur fuel rail a bit as the injectors are long
Heard too many horror stories about the siemens deka's to recommend them to anyone... My tuner told me to stay away from them, he refused o even install them in my car if I got them. They also aren't straight plug-n-play, you need to get new plugs. Not too much drama if you know what you're doing.
I ran Deka's for a year, they were fine. I only upgraded to Bosch 1000's because they were maxed. Either can be installed in the Neo fuel rail with an adapter, plug adapters or new plugs will be required also and rail spacing may have to be modified.
i do want to upgarde later on . if i was to get the 740 size that would do for all the mods i going to do and if a was to play with 85 they would work ?
who had the injectors swap thread on here with spaceing them out and wat not :thanks:
Siemens Deka IV injectors, 650cc or 860cc long ones, wide spray 650cc's have been working with Nistune on a neo motor with spaced out factory fuel rail for more than 1 year, no problems encountered.
480cc Nismo ones, purple - obviously work flawlessly and are drop-in.
Deatschwerks (or whatever is their name) make highflows for neo/VQ35 engines, drop-in replacement, no first hand experience.
InjectorDynamics make Bosch highflows in 725, 1000, 1600, 2000 cubic cm sizes - haven't tried these, but very keen to. Apparently they are nearly drop-in also.
Plenty of possibilities, just search.
Whaaat? You must be working too many hours Ash?
Nismo do make drop in injectors for neo's I have 480's in the stagea.
BAH! Ye i know.
I meant to his 550cc+ like he was talking. Posted from my phone/chopped a bit too much of it out :blush:
There are some 3/4 length drop in direct fit injectors that only require connector changes.
There was some reference on the forums somewhere. From memory about $450 + connectors.
If you can't find let me know and I will search. I think they are bosch or similar.
The XR6Turbos are full length but you can get them in the 3/4 length top feed also from what I have read
Sounds like the Siemens Deka's.
Bosch EV14 52lb
· Single buy set of 6 $450
· Group buy 5+ sets of 6 - $415
· Single buy set of 4 - $305
· Group buy 5+ sets of 4 - $280
Bosch I think.. 3/4 length
http://www.skylinesaustralia.com/forums/topic/352869-group-buy-siemensbosch-injectors/
These are a 3/4 length injector, 14mm Oring, top feed, high impedance, UScar style plug.
Height adapters are extra – used to convert from ¾ length to full length
Wiring adapters are extra – used to convert from UScar plug on injector to Bosch EV1 style
Billet height adapter with locking clips are $8ea, Wiring plug adapters $7ea. R34 specific wiring plug adapters are $11ea
11mm adapter to suit RB20 and 26 $8ea, 10.5mm adapter to suit standard fuel rail $16ea
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
