Given the people involved, the diagnostics they have been resorting to and generally giving them credit I'd think (or hope) that its almost insulting to make these suggestions on the assumption they weren't the first points of call. It'd be very interesting to see a datalog file as the car warms up, however - if that were a possibility?
You would be suprised
Amount of fuel to flow out of the injector is dependant on the opening time(For this purpose we will ignore injector lag times) and fuel pressure.
The more fuel pressure the more fuel will flow at the same opening time(This is also discounting changes in manifold pressure)
If you have a faulty FPR it could make the fuelling go all over the place.
That said if injectors are not getting a constant good voltage source, injector opening times will change, this will change the amount of fuel being injected but wont nessesarly change the pulsewidth's especially if the ECU is not seeing the same voltage drop
not sure if this is relevant
..but when i got my car tuned originally I had never changed the fuel filter. Must of been dirty, then i changed it oneday giving it a serivce and all of a sudden was running very rich .first got told it was a boost leak ,I thought it was FPR busted cause I had hooked fuel lines up wrong at first, but it was just a filter that changed pressures and threw my whole tune out.. :/
Trent fixed it I dunno how ...had him stumped for a while too...
Since most things have already been pointed out, what about the grounding of the engine to chassis, etc. I know the BA Falcon's have an issue where they would run rich and even stall, all caused by the chassis/motor grounding being installed wrong.
Well it basically has to be one of these things, how else does fuel magically get into the cylinder?
Tried another ECU that isn't a Haltech? I had a *very* similar issue along with some other "electrical gremlins" (intermittent misfiring and some other problems), the Haltech setup had been checked by many people whom could see nothing wrong with it - swapped it out for an Autronic ECU and the car has never run better.
Never did resolve the problems with the Haltech, as said many people had looked at it and said there was nothing wrong with the setup, it just would not work reliably in my car for whatever reason. Power FC had no problem, Autronic has no problem, Haltech had nothing but problems... *shrug* go figure.
Yeah this isn't the first time I've heard of nondiagnosable problems with a haltech, most people end up fixing it by using another ECU.
Might not be the ECU, might be some weird combination throwing it out, but sometimes its just cheaper and less time to try another ECU.
Yeah I was wondering about that too, ECU sounds like it CLAIMS its doing everything right - fuel pressure sounds right, something "lying" is the next most likely option.
yes sadly if you are paying a workshop $100-$150 an hour to diagnose a problem it can often be cheaper to switch to another ecu if the problem is specific to that brand ECU... considering you're likely to recoup 50-70% of what you paid for it the changeover cost to a new ECU may not be too bad.
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
