  • Replies 199
Jesus! I log out for a while and all hell breaks loose!
I don't suppose anybody got footage of my passes the other night? In particular the one against the Torrie?
they are 26 x 10.5 ET Drags
I've just ordered a pair of the ET Streets in the same size. What are the consequences of NOT running front runners with these tyres if you're going 116mph across the line?
Adrian
If they're the same as slicks (ie. very soft sidewalls), the back end tends to sway on the tyres... To anyone not aware, it would feel like the back is stepping out. With normal rubber on the front, it accentuates that problem because the front is tracking straight. Obviously your first thought is to provide some oppy lock to straighten it out - and that's where it gets dangerous!
Sticking skinnies on the front means the front of the car moves around with the back.
I'm guessing here - but I would think if you got a larger sized tyre (ie. 16 or 17"), the "sway" would be no-where near as bad as there isn't as much sidewall.
Cheers,
matt
Adrian
I was toying with the idea of borrowing Ben's (well known 10sec Yellow Supra owner) ET Streets for the next AIR Wednesday 4, 6 and Rotary meet. I'm not so sure now you've highlighted the "sway" issue Matt! Especially after nearly being cleaned up by a car suffering from this exact issue!
Thanks for that. By skinnies do you mean just skinny tyres or proper front runners?
I farking hate them to look at but i suppose if it's neccessary... Do they take some getting used to or not?
Adrian
I reckon about 6-8 weeks for the race GTR. We are waiting on brackets for the dry sump pump from queensland, & a timing belt from Japan. Once we get them we can engine dyno the engine(which is ready to go), then finish off the undertrays, mount the radiator in the boot, & it should be ready. One of the reasons it has taken so long is I was pouring $ into the street car instead of the race car, but now that is bust again we are full steam on the race car.
I am in Perth at the moment.Went to the comp meet on Sat. Saw jet cars running 5.0s, a rail running 5.0, a swag of doorslammers in the 6s, & a torana roll at the deep end.It went spinning on its roof with sparks flying everywhere thru the traps.Was a chick driving too.
I am racing the ute at the Wed night street drags tonight, then will be racing at Drag combat on Sat. Should be fun.If I cant race my GTR then I will race my tow car.At least I still get to do burnouts.
John,
Did the above occur at AIR on Sat? Or are you refering to another Torrie roll over with a female driver that happened in Perth??? If it's the latter then that is bloody freakish! If it's the former then go have a FULL read of this thread mate :):D
Hahaha.... ahhhh Erica you just cracked me up big time :D
It's a long story Steve.... but suffice to say I added together the only Swahili words I knew and ended up calling Erica a "bad donkey" :D Which is actually quite a compliment when you think about it, donkey ='s ass, hence "bad ass"
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
