  • Replies 199
ARGGGHHHHHHHHHHHHHH Steve you bitch! Damn it, I go out for a few hours and look what happens :rofl:
Steve, if you want to do some kind of a swap (with cash adjustment if need be) let me know mate. For your type of driving the 540's would be much better suited. It makes perfect sense to do a swap :rofl: We can chat about it at work tomorrow.
Either way, thanks for teeing it up Martin :P
Hey Matt, how's the single plate clutch holding up to all the abuse?
Have you noticed any slippage in 4th gear yet?
Cheers,
matt
A deal has been struck. Thanks Steve, you're a champ :spank: If all goes according to plan I'll be heading to AIR tomorrow night to see how I go :D
Matt, no prob's so far! Surprisingly the single plate has handled the job without protest. Then again I did manage to get over 20 passes out of the OEM Nissan clutch, some with 250+rwkw onboard.
AIR does have a website, but I can't remember what the address is? Try a search on SAU under 'AIR', as I recall someone posting a link not long back.
I'm gonna give it a good shot Steve! Just noticed GOT BOOST in WA ran 11.67 @ 120mph (1.6 60ft !!!) on 555R's, so even with my shitty driving skills I should go 1.8-1.9
Nice - I'm probably going to go os giken twin plate now. The singles just don't last! :spank:
Yeah - the Supra which ran a 10.9 ran a 1.63 60 ft with jap coilovers (ie stiff)... The nitto's are superb for that! You just have to rip a monster burnout to get heat in the tyres!
Cheers,
matt
That's the plan Joel. To get the Nittos doing their job you have to go for a big burnout. I'm ready to progress to Burnout Basics 102 :spank:
With over 350rwkw I can see why your clutch can't handle it Matt! With decent grip you should be looking at low 11's at least mate!
Yeppo!
All else going to plan (and it never does).. If I can get my 60fters down to a 1.6, I should be able to run a 10! :spank:
Realistically - low 11's would be good though!
PS - How are you on the gearchanges? Are you savage enough that it'll chirp 4th?
Cheers,
matt
That's the plan mate. To get the Nittos doing their job you have to go for a big burnout. I'm ready to progress to Burnout Basics 102 :D
Yeppo!
Cheers,
matt
Hahaha... you got in before I edited my last post mate. Yeah as I said above at the very least you'll go low 11's with BIG mph.
EDIT: Helps if I read ALL the post!
No mate I'm fairly soft with my gear changes. Quick, but not brutal. I never even get 3rd chirping! Unless the track is very slippery and my tyres aren't hot enough, in which case it doesn't just chirp it spins!
So when are you out next to test these nittos? I'll be very interested to see how low your 60fters get!
Cheers,
matt
Yuppo - I'm hoping to crack 125mph next time I go out.
Re: gearchanges - yeah same - I'm too afraid to be hard on the gearchanges as I'm afraid of the car going sideways at 100+ mph... Nitto's should sort that out though!
Cheers,
matt
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
