ROFL Dean..
Your guess is as good as mine..
But I do know, Tillbrooks are working pretty hard to get them finished. I think its almost been a year now that they have not been on the road. Its ironic, i have never seen John race the whole time we've been together, maybe I am bad luck?
Ps. Congratulations Matt... I wanna see your burnouts!
  • Replies 199
Andy, yeah mate the track was much grippier than the Wednesday night, as you'd expect. I still had 1st and 2nd gear w/spin on most of the passes, but 3rd was fine.
As Chops said there was quite a few running, but at least 5 passes would've been had from start to finish.
Congrats on the 11.93 Martin, I'm slowly working my way down there. If you go mid 11's at LS1 Nats then I'm out of the ball park again :)
I'd love to head over and run at Heathcote, Keir vs. Theo would be worth the trip alone, but it's just not practical for me atm :D
Henry mentioned Keir has a few 2nd hand sets of 275/40/17 NT555R's up for sale. I wouldn't mind snapping a set up for the right price! Maybe a 1.8-1.9 would see me into the 11's? If Ben did it then I don't see why I can't. Practice makes perfect.
Yeah Chops, Wayne got me lined-up in the water and then had me stay on it a LOT longer than I would have normally, and it worked :D Pity the Torrie stuffed me 'cause I was on a quick one :(
Yep Matty still on the same tyres I've been using all along! It was in my usual 100% street trim. Full interior, full exhaust and a completely chockers tank of juice.
I used to be a 14sec driver in a 12sec car, now I'm 12sec driver in an 11sec car :D
I had a run vs. a 32 GT-R - he ran 12.1 @ 122+ vs. my 12.6 @ 119+ and had 97mph at 660' vs. my 92mph. He had a clean pass once of the line, so it shows I've got more top end to come. I just need a clean 5k launch. The 32 had just the drivers seat left in the interior and a side pipe exhaust.
Thanks Erica :)
It probably would've been a bloody good and very close match-up btw you and that 32 GT-R Martin. He mentioned his quickest to date was 11.6 @ 125mph. He had a best of 11.8 on Saturday night.
I wonder how much extra grunt and ET/TS improvements I'd see from removing my exhaust and interior trim? Naaa stuff it... then it wouldn't be a "full trim street car".
I was all lined up side by side ready to give Keir a whooping, and the bugger cut the first amber, red lighted, and sucked me into the same. You really have to watch him being the car in the other lane. The acceleration from around 400ft is incredible. I checked his timecard afterwards, 1/2 track mph 122, mine 92. 30mph....GULP.
Holy shit, 30mph! That's a massive difference over a very short length of track.
92mph at 660' hey? My best is 92mph at 1/2 track. What rwkw and terminals are you getting in the Tonner?
Ive got around 295 - 300rwkw depending on the conditions. Have run 115.9 mph, but also have 1650kg + me to push. The biggest problem is the aerodynamic wind brake that the Tonner applies. It cuts the air like a poorly designed brick. Wipes maybe 3 - 4mph off it at that speed.
Yeah, its been the development bed for GenX2. The kit gave it - at this stage - 10mph and 0.8 seconds improvement over the baseline. Not bad for the money. Like I said though we will go faster, maybe around 11.6 ish. Then the GenX2 comes off, the stocker engine out, and the 427 cuber goes in!
If I was looking to upgrade my LS1 powered Holden I'd be very hard pressed to go past the GenX2 kit. It seems like a very well priced package!
427, very nice. Will that see forced induction too?
True.. Can't beat a big cranky V8.
Only thing that puts me off it these days (while i'm at uni) is the damn fuel consumption.
Hence why I sold my VS V8 that I spent shiet loads on modifying. 5ltr isn't a good option to modify. Once you slap a cam in them they tend to be rather gutless below 3500rpm. Powerband is rather narrow etc. It always felt like it needed a gear inbetween the gears I was in to pull out of a corner hard.
And Matt, GenX2 is ADR approved....
I want to make around 700hp (about 440rwkw or so) without forced induction using the LeMans developed Corvette C5R endurance racing components. Nothing like having a big cranky lump of alloy under the bonnet
Now THAT I can't wait to see!
Dont confuse old school V8 tuning with the latest generation stuff. Its a big mistake. Well setup a C5R should be producing around 500Nm, at 2200rpm, on its way to 900Nm by 4500rpm. It should only need two gears.... but a six speed Holinger would be better :D
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
