  • Replies 199
C'mon now, play nice everyone :)
God damn pool cheater Martin! Real pool players use their fingers :(
In all seriousness I personally don't see using slicks as cheating. However I do give a big thumbs up for those that run good numbers on street radial tyres :D
I'd be happier with an 11.9 on my road rubber than a mid/low 11 on slicks.
Adrian,
When Ben ran his 2JZGTE powered JZA70 Supra (was a cover car for Zoom) to a 10.8 @ 120-130mph it was on M/T ET Streets and his 18" chrome rims on the front. He ran it that way for a few meetings if I recall correctly. I don't remember him reporting any major car handling issues.
I didn't think it mattered what you did to get a faster time, as long as you got it..isn't that what drag racing is meant to be? (at air).. i reckon if you can get slicks matt, power to ya..
Why deny yourself a faster time, when you can have the slicks and get better traction... Just a thought.
I personally like knowing that my best numbers (in my sig) have been run in the EXACT same trim as I drive the car on the road whenever it comes out of the garage.
I don't view using slicks, purpose drag suspension, removing exhausts, pulling out the interior and so on... as cheating. However, I PERSONALLY "do" see these things as taking the shine off MY end result, hence I choose not to do them - at this stage.
There are sooo many variables that people can, and do, view as "cheating" that it's ridiculous to call ANYTHING cheating! You may as well say that any change from the original standard vehicle is cheating :(
Once again, I PERSONALLY, believe that comparing 1/4 numbers from a car using parts/mod's that are NOT legal (never have or will be) for road use (slicks and Nitrous as examples) vs. a car using only mod's that "CAN" be made legal (larger turbo and ECU upgrade as examples) is pointless. It's my opinion and I'm entitled to it. I'm certainly not taking anything away from those that do use non-road legal mod's, faaar from it!
The bottom line is... Run what ya brung and hope ya brung enough :D
If a Skyline (or any car for that matter) runs quick numbers over the 1/4 I don't care whether it's using nitrous, C16, LMS, no interior, slicks, fluffly dice, a dancing Elvis on the dash or the driver has his eyes closed the entire length of the strip. If it runs the numbers then I'm impressed!
I'd like to clarify that I do not race on the street. My preference to run in street-trim at AIR has nothing to with illegal street activities.
Can't really say whether front runners are needed when using the ET Streets...
However, if they're like Nitto's, then you should be fine!
Cheers,
matt
No-one's answered my question about the need to run front runners with M/T ET Streets.
Any ideas? Martin?
Adrian
Its pretty funny, this whole street trim debate - street trim can include Hoosiers or Nittos - and there isnt alot of difference between the numbers, that I have seen, to cars of a similar state with slicks. (eg, Ben Ellis's R34) But are hoosier's or nittos tyres that you would drive around on all day? Still street trim.
A lot of the old school drag heads, run cars that are designed to go really fast in a straight line, and not much else. They may be in street trim, but they corner like a dog, and with high stall converters and a high power band, leave alot to be desired in the street driving.
Matt, throw the slicks on there FFS, its a drag strip - start fighting fire with fire, and lets see what a car that can be driven in peak hour traffic, or down to the local shopping centre can do if it wants:)
Would you put a drag car on a circuit with drag slicks? why drag as a street car on a strip with street (or circuit) tyres? You know what can be achieved in street trim, why not up the ante and see what the potential is?
What ever you choose to do, good luck [subliminal message]
go the slicks, you know you want to, dont be weak
[/subliminal message]
If you use conventionals on the back eg ET Streets and radials on the front, you are asking for big trouble. Wait till you get half a turn of lock on towards the deep end due to the sway, then go check your undies. ANDRA tracks like WSID wont let you do it over 110mph (?) as a safety issue. You will struggle to make a hit on the HPI list in your car on radials Matt, so why not cut a proper time. Compare apples with apples.
Steve, you should actually try driving a car with a properly setup stall in it on the street. Ive got a 4000rpm, Henrys got a 3800rpm, we can both drive away from the lights at 1200rpm no problems. In fact a good street auto NEEDS a high stall to be some fun.
Nothin like clickin top gear 10 feet out of the hole with both tyres alight
Fair comment, I have only driven one car with a high stall converter (from what you are saying obviously not set up well), and it didnt do much until you put your foot in, then it did alot:) made traffic a bit tricky, there is on way I would have attempted to drive it in the wet - had enough trouble with my GT falcon, and that only had a 1500rpm converter (not quite what you would call high stall though).
Sounds not to bad.
A little better than my old VS after it had a little bit of work done to it.
I was getting around 16L-17L/100km's, then it was a pig under 3500rpm.
I really should have opened her up and upped the comp ratio. :(
Problem was it then spat a rear IRS crossmember then a gearbox then the diff, so I couldn't afford to open her up :(
Full of dissapointments that car.
At first it was around the 14l/100km's.
So thats definately squeezing the throttle then, not simply resting your foot on it. :) I have to admit I like squeezing the throttle. :)
Mind if I ask what sort of mods?
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
    • I know this is a super old topic, but what ended up being the problem?
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
