hey guys reluctant sale but time to move on and save up for a house. if you are interested please pm me.
1989 chassis S13 Onevia all interior/engine/rolling fear and parts are from a 1995 180sx.
Engine
SR20det 86,000kms
Apexi ax53b70 turbo
turbotech boost tap
bosch 040
740cc nismo inj
Z32 afm
hks pod/intake
catch can
Gktech overflow
isc 52mm radiator
Au thermo fan conversion
Gktech returnflow cooler kit
justjap 1 piece dump/front
jasma 3inch twin pipe from catback into twin tip
catco highflow cat
oil cooler w/ relocation kit
apexi power fc w/ hand controller
suspension
Cusco zero 2 8kg fr 6kg rr
just jap swaybars with superpro bushes
front/rear strutbars
engine damper
drift pinapples
driveline
sr20det gearbox (never crunches)
Excedy 5puk heavy duty cushion button clutch
nismo 2 way diff
exterior
electronic sunroof
genuine gp sports front bar
vertex side skirts
vertex rear bar
custom cut flared and welded 50mm rear guards
180sx front
5 stud conversion (s15 brakes/hubs/rotors/lca's)
deleted spoiler holes
Aerocatch bonnet pins with keylocks
black d1r wheels
interior
carpet/dash/seats from 1995 180sx
all sound deadening removed
interior sprayed topsecret gold under carpet
Drift oil pressure, oil temp, water temp, volts gauges
Saas Boost gauge
impul gear stick
OMP dished steering wheel
Drift button
digital climate control, compressor just needs gassing
sound system
clarion 6x9 rears
pioneer 6" front
jvc headunit
not installed but have blaupunkt amp and kenwood sub would throw in for free with wiring kit
car was tuned by chequered tuning (status) made an easy 223rwkw on 16psi with more left in her, tune was done to be very fuel efficient while not running lean, was getting a little over 500k's to the tank of 98ron.
car is very reliable, Sprayed VE commodore karma metallic with purple bonnet, car is registered with 6 months rego. this car is track ready also, if u want just chuck a half cage and some buckets and u have urself a mean drift car.
after $11,000ono, or straight swap for a daily or swap plus cash my way only, depending on the car. car is serviced every 5000km's with anglom oil. pm me mob number if u are interested and u would like photos. cheers.
Edited by crzy_180
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
