lowering my skyline
Yep ! Cluster out first. Dismantle. Check for oil grease. If oil and grease = clean. Then check seal at the drive coming from the gearbox. Seal broken = change seal. Doing it the other way around it will again push grease/oil back into the cluster and then your gonna have to do the cluster clean all over again !
Not sure doesn’t have one the car had a full respray before I brought it but I’m guessing 205/55r16
So if anything it’s be the seal speedo drive sorry it’s being awhile since I worked on one of these is the drive connected to the gearbox or behind the cluster
