Finally after a long wait and ages of tinkering around with getting it perfect.....we have the "son of a peach" in primer and ready to go........excitement overload !!
and.....
and...........
and..........................
and..............................................
What's with the bases of the two uprights? They don't look symmetrical at all, like the one on the right has a lot more 'bulge' at it's base. Could just be an illusion?
Correct....good spot...Excess filler around the base of the stem.....if you look carefully there is a huge gap between the two uprights (on both sides - basically around the light) as well that needs filling and sealing....issues that are currently being worked on.
Bit like cosmetic surgery really...I should name my wing Jacksons nose !!!....(RIP).
It was still work in progress at this stage....so just progress pictures really. Will put up completed pictures asap.
Not usually the type of person to say anything about a thread however I've made an exception for this one, :)
Your car is the best skyline ive ever seen, The way you've simplified many a mods (repainting certain things, the mesh, the pipes) is bloody spectacular.
You and your car have inspired me to clean my own up.... spend the money and get a panel beater/spray painter to get rid of a little rust and get some chips out before it gets shipped up north to darwin.
i cant get over how you have found the right mixture of stock and aftermarket to keep it looking clean.
Bloody spectacular!
Look forward to the write ups to come, awesome to read!
Bronson.
That's a big wing...
Yeah I know....I was positively pooping my pants driving back home.....border line now with what I want with the car........I want it to look awesome......but I want to keep it registered too.
Earlier....before getting the wing fitted......
7233f1ff-56bd-40fc-a372-6af856b307e3_zps
That wing tall as fuark.
What are the effective offset and widths of your wheels? They look good.
Yeah I am not sure I am completely sold on it yet....but there are times I absolutely love it.
Rims have an original offset of 35.....fronts are now with a 15mm bolt on spacer.....rears have a 5mm slip on hub-centric spacer (soon to have a bolt on 15mm when I get a chance to flare the lip a tad).
Different view....
All the cats are scared of being killed obviously.....by curiosity !!
So I will spill the beans.....or cat food.........................
The package contained a carbon fibre drift lip spoiler. I have decided that the big wing is going to attract a lot of unwanted attention so I will reserve it for the odd outing now and then. Will be getting a bootlid off Bronno soon (thanks mate in advance) and will mount this new spoiler onto that and keep that as my daily option for a while.
Also lining up my next project - Ass :bunny:
Aim: To be wider and more aggressive.
Will involve: Running bolt on spacers and more camber and flaring of the rear arches.
I found that the car cover that I was using was leaving very fine scratches on the paintwork as it was blown about in the breeze so I decided to get mom to help me fabricate a flannel "inside" cover that would protect the paintwork. Took a fair bit of effort as we had to join numerous bits together to cover the whole car.
Big thank you to my mommy :yes:
Next step is to run elastic around the bottom edges and hem it up....
And also attach velcro straps that will go around the rims.
Started a headlight restoration project this morning....
Before: Aging, foggy, scratched and yellow
Other side headlight but you get the idea....
After: Fresh, clear, bright, no scratches and shiny
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
