^^^^^ Cheers mate......yeah seems I have been "spoilt" for choice by way of spoilers at the moment !!
These are in the mail........hope the gamble pays off....have heard mixed stories - BUT WE SHALL SEE :geek:
They will look awesome how do you fit something like that.
+1 for gtr front fenders
^^^^^ with a fair bit of work to be honest.....but its the road I have always wanted to go down so there is no turning back now.
They arrived this morning......
My mini project is well on its way too.....
Update:
After a bit of searching around for some place decent to have the work done I have narrowed it down to two possibilities. Either way cars going in in about a weeks time for the fender work... :)
Picked up a rear strut brace this morning...currently fitting it up
Had to sand back the spots of surface rust anyway...so decided to give it a lick of paint while I was about it.....
Edited by jez NF
Few small updates:
Rear brace all fitted up......(forgot to take a picture).....no noticeable difference in handling (as expected)...tad more rigidity at best.
Took Tom up on his $69 service offer at PZP because I was being lazy and got an oil and filter change.....can swear the car feels smoother but then again you are supposed to think these things !!
Currently speaking to Andrew at Maddog Customs - want my rocker covers painted and engine bay tidied up a bit.
Also waiting to hear back from the panel and paint place - car was supposed to go in next week for the fender work.
Project: Rear over-fenders
Dropped off the car.
Discussed options by way of cutting out the arches thereby achieving more clearance, welding the inside and outside edges together to prevent any moisture and dirt getting in and getting a "smoother look" and also looked at possible rim fitments down the line.
SAU is really dying......members hardly post anymore :/
However....I will keep updating this thread because I am still very much in love with my car and what I do and besides it helps me keep track of what I have done when.
So update:
Went to the panel and paint place this morning to check on the progress being made......its coming along nicely - almost ready for primer.
(did not take any pictures)
I also picked up a set of rocker covers (thanks Selven) which I plan to prep and paint myself - with a slight rather interesting twist...so stay tuned for that.
How I got them....
After a good degrease and wash.....
Absolutely love the thread mate, always been watching it, just never comment on anything, never found a need haha, I'm also from Perth and finally got my skyline back yesterday after a long time, be great to have a chat and so forth.
keep up the good build
  • Like 1
Cheers Cameron :)
Scott the guard project was a great success.....it is subtle enough to not "stick out and slap you in the face" and mean enough to "create a stir".
I LOVE IT - just waiting to get the rims out a bit more and I reckon it will look wicked !!
IMO the car is looking the best it has ever done.......
  • Like 1
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
