Good on you Jez for looking after it the way you do. I just know when your older and these cars are no longer as common on our roads that it will be worth some money for it's condition. But Jez, the wheels, get some dish, same colour, just more dish.
Yeah Gary....I know....im working on it at the moment (savings wise I mean :yes: ) Satin black Te37s or deep dish gold and silver two piece rims is what its going to be....fingers and toes crossed !!
Nice sunny day today....so after I took a casual stroll to the shops and bought some green goblin juice...I topped up the coolant and gave her another good clean up. Then I proceeded to search for tutorials of how to take off the rear view mirror...because I could'nt for the life of me find any screws etc. You yank it off I was told...so thats what I did..and hey presto..it works !!
Plastic primer and then first coat......
Finished product to come soon.....(waiting for it to dry)
VERY HAPPY :P
Extremely satisfied and happy with the finished product.....NO SMELL of paint whatsoever...even with the windows up all night. Looks amazing....and brings me one step closer to the "sleek black" front end look that I am after.
Finished product pictures as promised.....
Very hard to get pictures of it clearly with the tint strip....but hope this sufficies
Edited by jez NF
New project: Door trims !!
Started by taking off the door panel.....three screws at the bottom....one screw inside the plastic "phone holder" thing...one screw behind the door opening lever and one screw underneath the "holding on at high speed handle"
Then I wedged the panel loose......carefully disconnected the power window wires.
SUCCESS :woot:
Started painting the various bits and pieces since they were off anyway......
Before...........
After the first base coat.....
Ever wondered what goes on behind closed doors ;)
Ready for renovation...........
Cutting the new leather inserts to size...they are the same material as my seat covers....matching much :whistling:
Stay tuned...progress pics soon....
Hey Hadouken....I guess time will tell hey... :cheers:
BUT..........these are the reasons why I think it will work / is working already !!
1. There is actually a lot more room to "tuck it" into which cannot really be seen with the naked eye...
When you use a flat head screwdriver it works wonders and I actually pushed in quite a bit of the material...a LOT MORE than I thought would
go in. It kind of goes in and under if you know what I mean.
2. It is held in place by the door handle...the door opening lever and the plastic trim bits sit snug over the material.
3. I dont exactly plan to let the neighbourhood cats come and have a free back scratch.
4. ...and my trump card....hahahaaa...I did use drops of super glue in "strategic locations" :whistling:
I think it looks really nice...so even if it does open up...(which I highly doubt it ever will) I will just do it again.
:thanks: Matt..............yeah they are a quick fix with quite amazing results !!
:thanks: Kory.............hahahaaa..I try and keep myself busy and I love working on the car.
Jonno.......Whats next :miner: with the B :ninja: lackization .......ummm....I will finish off the door trims (drivers side) by tmrw / day after.....then next week I plan to get started on my front bumper.....touching up the stone chip marks.
I also need to get started on the brake calipers......and I want to swap the back wheel from one side and put it on the front (the opposite side) just to give me an idea what a "fatter" "deeper dish" and more aggressive wheel looks like..then when I have two rims with decent dish and offset and can look at the car from one side I am hoping this will help influence my decision to get my new rims quicker.
ALSO.............................................she hasnt been on a dyno for a while.....
so CARS GOING IN FOR A POWER RUN (and general check up)........on wednesday to PZP....my current workshop closed down :spank: (the b@#$%ds) so now have to find a new tuner and get comfortable with a new workshop....
Stay tuned
Happy with most things but Tom reckons the AFRs could do with a tweak and there is scope for improvement...so retune next week.....
Meanwhile....I finished off the drivers door this morning....and in the bargain have now completed the door trim project..woohoo !!
Before.....
After......
Thanks to the mad skills of LJ (your awesome man).......
New boots :wub: .........................................................................................................thoughts??
In other news..................cars being retuned tonight.......yay !! :woot:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
