Thanks for the heads up Dale.....btw - what are the disadvantages of going with a 20mm on the rears?? Is there a massive difference in performance etc. Will it even be noticeable? They have access to the fronts..waiting on the rears (want 22mm).
Bored of waiting for the sway bar install and the wing is still work in progress so took the car out for a drive this evening.....few pictures :)
That ass :wub:
b1ab3db8-0490-4458-85ba-979698abb61a_zps
Kicking myself for not taking my camera...was such a nice evening !!
77c1a4fe-b4d8-4e0a-862f-d1e44c577ee9_zps
Don't quote me on this, I'm no suspension guru but from what I remember a big front sway bar and stock/small rear will increase under steer. So make sure you go a a decent size rear......no one likes under steer.
Yeah thats for sure Justin....I have read up a fair bit and for what I gather the stock fronts are 18mm so if you go a 24mm solid or 27mm hollow front they are more than sufficient and rears should be 20 solid at the very least to make any significant difference - though I have ordered 22mm solid anyways.
No clue when they will get here though :/ bummer
The supply issues Whiteline have been encountering are very close to being over; if you like; PM and I can give you some background on why it is happening.
Swaybars are arriving early next week - car booked in for Wednesday morning (YAY!!)
Might be getting my guards rolled today (if all goes well) or possibly next week as well...so can get the rears out a bit more and possibly lower the car a tad.
Gave the rear guards some good old fashioned "hammering" this afternoon....works a treat if you grind little cuts strategically along the "metal lip" bit which basically allow it to bend backwards in sections rather than attacking the whole piece as one - (as Brad and I found out halfway through)....should not chew up the tyres now.
df14db85-83aa-4884-a3dc-6531e822ecb2_zps
There was a little bit of paint flaking from the undersides despite our best efforts with the heat gun. You could not really see it unless you squatted on all fours - but I am crazy....so a light sanding and rattle can spray job was done on the insides of the lip and the underside of the arch.
672c3e16-d133-4b46-a23e-4fda41494662_zps
Awesome idea about the slight cutting.
I tackled the whole thing at once and it was a big job that took a lot of patience.
What technique did you use?
Pushing hard against the outside and just tapped away with a hammer on the inside?
Yeah....wrapped a hard bit of metal with soft cloth and after heating the guards held the outsides with a fair bit of force and let loose with a fairly heavy hammer on the insides. We tried the left rear as one bit and boy was it a pain in the arse !! Halfway through we decided to cut sections and man did that help. The right was a breeze with this new technique and wrapped up nice and tight.
A good job overall and definitely no scrubbing etc...even when it squats while launching :woot:
Yeah had the guard roller but ended up not being used.
Had the new sway bars installed this morning.
Rocked up first thing and parked amongst some interesting company......
Up up and away.....
Wish I had one of these bad boys at home (hoist)....would make life SO much easier :/
6d9027f5-f15a-42d7-b6df-e713558674d4_zps
Out with the old..............
In with the new......
4e2a069e-ca76-4c08-824b-ad2f6cc1b782_zps
Back on solid ground and ready for a test run.....
24b5fbe8-1b2d-496d-a659-3450919150d1_zps
Verdict: Freaking awesome !! Massive difference !! Virtually no body roll and much tighter lines through twisties.
Hard on the rear and medium on the fronts is the right combination in my opinion. Glad I went with medium on the front because I can feel the slightest bit of "stiffness / harder to turn in" compared to before. I reckon the hard setting would be too much.
Small update:
Painted the spacers on the front the same colour as the hub to "disguise" them as far as possible.
On another note....how hard is it to flare the lip / edge of the rear arch??
Something like this.....
It will take a lot of patience skill and it'll more than likely need filler and paint after unless you really know what your doing. In fact allow for paint no matter how good you are lol.
Hahaaa...yeah Brodie....will work on that hurdle when I get to it....but it looks real nice so knowing me that will be my next project.
Picture of how the spacers on the fronts look now........
Spent this evening down at the workshop getting the wing project moving...taking forever !!
BUT PROGRESS IS BEING MADE................
Ensuring that it is well reinforced and that the light still works so after a few teething issues it is now well on track....
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
