Hey guys is having wide rims like 10.5inch on 34gtr unroadworthy? If it come out the guards would a bit of camber sort it out and make it legal or is their more to it?
And also regarding streching tyres is that unroadworthy as well?
Ps love all u sau'ers
https://www.sau.com.au/forums/topic/377529-roadworthy-question/
Stretched tires are not legal wouldn't really recommend it on a gtr myself..
As for wheels you would find they probably aren't legal however if they are inside the guards at the top you'd likely get away with it, again wouldn't really run mich Camber on a gtr if it was me
Why no camber an no strech on gtr? Affects altessa?
For safety reasons, tyres are designed to fit on a particular width range of rims. If you have to stretch the tyre to fit on the rim, the safety of the tyre / rim combination is compromised.
Check the VicRoads website for the rules, but I think the rule limits rim increases to 1" in width and 2" in diameter.
tyre stretching can be done within reason and not effect anything at all, depends what you have in a mind a 10.5 will need a hefty tyre i wouldn't go less than a 255 on a gtr personally but you'd get smaller on no problems.
and yes camber/strech will effect your handling
^^^^ what he said. They check to see that the wheel is in the guard. No poke. And they check the width of the track of the tyre. Basically if you're rubbing wheels too fat then you would have increased the tyre foot print of you're car which isn't kosher with gayroads!
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
