Saunsw Drag Day Wrap Up Thread
N1GTR
 Share
hahaha 406.74MPH!
Too bad the lady wrote incorrect speed on it. But I did get one where it says 192.38MPH.
Anyways thanks to all involved for organising this. Too bad it was wayyyy tooo hot! >.<
192MPH!! on the left:
  • Replies 114
I'm stoked, I got a 14.507 @ 91.6mph on low boost (9psi) in the morning with a fair bit of knock due to the heat (it was already close to 30degC at around 10.15am). This was my second run, and I've never dragged before.
In the arvo with the cooler weather, I did a few more runs in low boost to check for knock, then went for it in high (12psi) and got my best run of a 13.817 @ 95.23mph on my second last run.
Not bad for an RB25DET Stagea with minimal mods (full exhaust, return-feed FMIC, PowerFC, EBC and fuel pump) running an otherwise standard engine and turbo. I wish I'd remembered to check the weight during scruitineering, but it would quite easily top 1700kgs.
:banana::bunny::banana::bunny::banana::bunny:
Massive thanks to all the SAU-NSW Exec crew (Eric, Dave, Duncan, Liz, Shell, Steve-O, etc.) and our volunteer support network (BenM, Sean, Mitch, etc.) for putting this together.
Also thanks to our very own Tats for the commentary throughout the day, he sounded much more professional than I did over the PA system
Funnist moment in there-
Me " just a little lower Louise"
Bahahaha. I still find that funny!! Lol
Thanks to all for a great day, well run.
Only had eleven runs due to the heat, car run like a swiss watch all day, worst run was my first with a 12.7, best was a 11.3.
took plenty of pics and vid, will post up later. :thumbsup:
BIG Thanks to Dave and the SAU team for hosting such a great day cant wait till the next 1(if i can come again)
Ran 11.4 on the fist run on low boost then 11.7 on the 2nd but the block split half track witch ended my day
Highlight off the day was watching the silver Skyline with the Microtech sticker on the side off it running a 12 at 130mph this thing was sideways from the start to the finish line he must have big balls to drive something like that
Thanks again Todd (Black Dato 1600)
Was a great day me and my wife were there for the nissansilvia.com drifting,
But we spent half our time watching the drags, one of the best days out we've had in a while
I thought I saw you out there, but wasn't sure if it was. You were both wearing black?
Thanks to SAU:NSW for organising a great event, shame the car called it quits just before lunch (silver 1600).
Had 4 and a half runs, best was the very first one of 11.6 @ 123mph 1.8 60ft
Best mph was 125
Awesome to be able for have 4 runs within an hour, compared to 1 run per hour on Wednesday nights.
Picture of snapped cv spline.
Aww really you should have said hi, yeah that was us, I don't own anything that's not black, I was there with my new 200sx Im considering buying a track only s13 or r32 for drifting now
Nice one Pete :) I better pull my finger out and run a decent number in the 200 or your going to catch and pass me :D
Not likely mate. 2 second 60fters for the rest of the runs
Speaking of Pro street towing......Joe towed me back home after I broke my cv - nice guy to come out on a nice Sunday afternoon
I hear from him the car is back at UE for the injectors - had mind put in an tuned on the Thursday night.
YOU MOFO'S WANT SOME PICS???
If you entered and arrived on the day you'll have a disc sent to you in about a fortnight. Until then here's a a few to keep you going :D
LOLvo
damn double watermark. grrrrrrrrrr
Will add a few more tomorrow morning if your good tonight.
Edited by MaTBoY
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
