  • Replies 114
Sorry Mark, I wasn't shooting the video. Was reall good of Joel to take my camera and get so many runs on video. Now that my time and duties are so full on, not sure how much video work I'm going to be able to continue to do.
Shame we didn't get more of the Starion. I remember loving those things in America when I was younger. They represented the "New Breed" of turbo car believe it or not - hehe!
Some times I miss my Mitsubishi Eclipse (was a fun little car for a stocker). The eclipse replaced the Starion in the 90's as their flagship hot little turbo car. Was probably the fastest car I owned before the GTR.
y music? i wanna hear the CARS, thats more than enough music for my ears! lol
I agree. I am sorry but the music is so bad i couldnt even get past the 2 minute mark lol
Sorry to the guy who did the vid. The editing is awesome and the you certainly got in amongst it all and got good footage but music in vids like that just isnt my thing. The cars make much better music in my eyes :D
i agree with less music and engine singing, could have let some clips go .5 second longer and showed the times
Ok Boys -n- Girls, here you go. Pure sound on this one, music has been removed. I lengthened the clips where I could but some didn't go all the way to a time at the end.
Hope you enjoy.
Good News Everyone!
I've finished off the Drag Day Photos. Everyone who drove on the day will get a disc with over 400 shots. All shots are in both High Res for printing/slideshows at home and Web size for sharing with friends/online buddies.
I cranked up some music (NERO) and let them play through as a slideshow. I hope you all enjoy them :)
Feel free to head down to Dick Smith/Harvey Norman to print out your favorites! If any of you want some Premium Prints (Excellent paper/Excellent photo lab) shoot me a PM. I'm happy to help organise them.
There's a butt load of discs to be burnt, I'm aiming to have them all done and ready for post at the end of the week.
Thanks to everyone involved for letting me cover the day, and thanks to everyone who turned up and fried some tyres! :)
Postman drove past my house again today, but he didn't leave anything. :(
Any of These posted yet?
Good News Everyone!
Outsiders point of view, but why wouldn't you organise a day with double the amount of cars, half the price, and maybe 50 runs instead of 100??
Nobody realistically wants to run a million times, or pay excessively for a drag day. Bigger numbers would be a better day socially too.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
