Got some adjustable rear toe arms, a must have for low cars. Suit s13,180, r32 $100
Cusco castor rod brace for s13,180, mayb r32 $125
Solid subframe pineapples to suit all nissans $100
Hicas lock bar $100
https://www.sau.com.au/forums/topic/377544-suspension-bits-sa/
