Got some adjustable rear toe arms, a must have for low cars. Suit s13,180, r32 $100
Cusco castor rod brace for s13,180, mayb r32 $125
Solid subframe pineapples to suit all nissans $100
Hicas lock bar $100
Contact via pm or txt on 0430133943
Can post
Located in valley view
https://www.sau.com.au/forums/topic/377546-suspension-bits-sa/
