Hey Guys, I have been collecting lots of R32 and R33 parts over the last few months and wanted to post them up here for sale before I put them on Ebay.
I will upload pics of the parts tomorrow afternoon as its too late now to get any decent shots. I would also prefer to have the items collected from near Wetheril Park NSW (I might consider shipping if needed)
R33
  • 1 x R33 - Series 2 (With Air bag) steering wheel: $200: Steering wheel is in immaculate condition, the steering wheel has almost no signs of wearing (no rips, tears, cracks or fades on the leather). And the air bag is un-deployed and non modified. The wheel has only about 2 or 3 tiny (around 2mm) marks on it but defiantly one of the best. I no longer need it as I found a near new R32 GTR wheel for my car
R32
  • 1 x R32 GTR (Late Model) steering wheel: $30: Steering wheel is in average condition, it was the original wheel which came with my car, its worn out on the top and sides, hence why I replaced it. However it inst damaged and can either be used to pass defects or if you are not fussed.
  • 1 x R32 GRT (Late Model) horn button: $30: The button is almost brand new and looks amazing, it works and has no cuts, digs or rips on the material at all (I might consider selling the horn and steering wheel together at a discount rate if asked)
  • 1 x R32 GTR 2 DOOR Passenger side interior door trim: $40: The passenger side door trim is in good condition, the material has 3 small digs in it (in the very top left hand side corner, another 2cm below it and 1 in the bottom right). The suede material has been carefully removed (as I intended to have leather door inserts put on), but the material is in perfect condition.
  • 1 x R32 Gun Metal Gray Drivers side folding power mirror: $30: Mirror works perfectly, both the fold in motor and the electric mirror. The upper portion of the mirror has started to fade, that's why I replaced it.
  • 2 x R32 FOUR DOOR Seat belts (Belt assembly itself, buckle, bolts, metal slider, and plastic to mount onto chairs), for both front drivers side and passengers side: $60: The belts themselves are fine, and have no wear or damage, however I wanted to have the 2 Door version in my car (with the clip for the driver for easy access) that is why they are for sale
  • 1 x R32 GTST factory orange front indicators: $40 each or 70$ for the pair: Indicators are in amazing condition. No cracks, no digs, scratches or imperfections, they are standard factory orange corner indicators and have all of their factor mounting points still intact.
  • 1 x R32 GTST/GTR fascia surround (contains the surround itself and ALL the hazard, fog, radio and other buttons, including wiper and lights). $70: The surround itself is great, ALL of the white lettering on all of the buttons and controls (including the windscreen & lights controls) are still intact. Also all of the light bulbs still light up (dim standard lights). All of the buttons work as they should and has no cracks, scratches or abrasions. It is finished in a MATT GTR Black (not tghe glossy GTST black). However, there is one small scratch on the light control and two small holes were it looks like someone has attached a boost gauge or something. Will consider selling the switches or other parts of it seperatly.
  • 2 x Centre Console cover (black / gray vinyl cover). $10 each: Material itself is perfect, has almost no signs of wear (doesnt come with the actual lid, its just the material that slides on top of it)
  • 1 x R32 Handbrake: $10: Standard R32 handbrake unit, it ok condition, the material has faded on the leather band, but mechanically it works just fine.
  • 1 x R32 2 Door drivers side, exterior plastic piece (the piece that sits right at the top of the door): $15: Good condition, the material is no longer the really glossy black that it used to be in, but isnt massively faded and still looks good).
  • 1 x R32 GTST Dash: $50: Dash in good condition, however has a bubble forming on the passenger side, other then that the material is still soft and doesn't have any rips or tears. Also comes with the top left, and top right front window vents (but not any other vents).
  • 1 x R32 GTST in white: $60: Wing is in great shape, its rear light still works completely and has no major rips or tears in the paintwork (however it has been in the garage for a while and might need to be painted to directly match your cars colour).
  • 1 x R32 Gearknob Cover: $10: Black leather gearknob cover, in ok condition (starting to look worn though),
  • 1 x R32 standard Orange 1/4 indicators: $15 for both: Standard orange indicators which sit in the front quarter panels. I took them out of my car to replace with clear ones, they still work fine.
  • 1 x R32 2 DOOR driver side exterior piece (the piece that sits around the door, shaped like an 'L') $20: Piece is still good, no massive scratches or issues, works fine, I replaced it before I found brand new ones
  • 1 x R32 2 DOOR passenger side exterior piece (the piece that sits around the door, shaped like an 'L') $20: Piece is still good, no massive scratches or issues, works fine, I replaced it before I found brand new ones
  • 1 x Used Pod Filter + Heat Shield and adapter to fit R32: $25: I replaced my old setup with a standard R32 airbox, works fine though and makes it about 30% louder then standard (atleast on my car)
In addition, I have a set of 4 17 inch rims (multistud) which fit a Nissan Pintara U12 (1990 model). I have sold the car and don't need them anymore. They are 150$ for the set. It still has some tread on them, but the front and back left rim has become slightly buckled but still drivable.
Other stuff to be added when I can start to go through it all.
Contact me if you guys are interested either on here or though my email: [email protected]
Thanks!
https://www.sau.com.au/forums/topic/377552-selling-r32-and-r33-parts/
Hey guys,
Found some images of my Side Mirror, the passenger side door trim and the two outside pieces.
I will take more pics tomorrow and will use a decent camera so you can see all of the details.
Regards
Pm's responded to.
Ill get those pics up today sometime for those interested.
Steering wheel is sold pending payment, ill update the list as soon as they are 100% sold.
Also not sure about postage, I will need to look into how much it costs to send items interstate :P
Hey guys, here are some pics, I also found new items: contact me if your interested in anything
  • R32 front speaker pocket: $20: Excellent front speaker pocket, removed the back mesh so its see-through
  • R32 rear boot lock mechanism: $20: works perfectly
  • R32 Badges: $10 each: R32 front blue and chrome badge and R32 side green GTST badge in excellent condition, GTR Badge (not sure if genuine)
  • ?? Speakers: $10 each: Not sure what these are but they came from my R32 when I got them?, they still work but are ancient, maybe someone can use the mounting plastics
  • R32 GTST Gearknob (Black): $15: Standard R32 GTST Black gearknob, worn.
As a heads up, the dash pics were taken at night inside my car, so they might look a bit shitty.
If you guys want anymore specific images ask me and ill try to provide.
Edited by playboi14
Still taking offers on some on the items guys, anything reasonable will be accepted.
Can be contacted through [email protected] or through the email service through here.
Hey guys,
Sorry about the VERY late reply, I tried to answer as quick as I could but for some reason the forum was down?
Anyway Ive send replies!
Still taking reasonably offers or any parts, I am also thinking of splitting and selling different parts of a set of items (i.e. the dash cluster, buttons, outside frame etc) so contact me.
I also managed to get a much better camera, so if anyone wants pics ask me and ill get them for you
Hey guys, as an update the Drivers side front orange indicator is sold, and the random speakers I found.
I actually have more stuff to put up soon, and some of the old images I will be adding more higher quality images also.
Anyone else interested in these parts? if it doesnt get all sold in the next week or so I will Ebay the main stuff and send the rest to the tip.
Anyone wants to contact me" 0432549307 or my email: [email protected]
R33 S2 Wheel and other small pieces sold, Anyone want anything else here? I created a new topic section just for the dash surround parts if anyone is interested, im selling each part seperatly.
hey mate is that centre console plastic trim that goes around air-con panel, and shifter still available? It holds the coin tray thing as well?
Not sure what plastic you mean? I dont have the plastic surround that holds the ashtray if that is what you mean.
Also guys parts are still available, I would like them gone soon.
Send me a reasonable offer on anything listed and its yours, else im just going to throw most of it out :P
Hey guys, Handbrake and gearknob surround have been sold. Still a few other pieces available if anyone else is interested!
I will be getting back to the people who have requested international postage, I just haven't had the time to see how much it will cost, I would prefer to have it picked up from my place.
Regards
Hey guys, sorry for the delay.
Dont have the R33 Dash Surround sections mate.
Also I only have on front indicator, so I dont think it would help you pass a RWC with just one.
Also, I have sold the R32 GTR Horn and Leather gearknob surround
The R32 handbrake is gone as it was needed.
I still have a few other small parts, R32 gtst gearknob (worn), 2 x vinyl arm rest covers, r32 dash, r32 side plastic pieces, and GTST front badge (blue), side GT badge (green) and the dash cluster (Also with the various control buttons etc). Also the r32 wing, and a U12 Pintara wing.
Its all slowly going, but would like it all gone :P
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
