  • Replies 71
How much are these 200l drums of fuel? Must be better then pump price buying bulk ect, keen for some 98 ron
around double the price, definately not cheaper but drums is the only way to get e85 in some areas and its the only way to get the race e85
price has just gone up to $550 a drum.
I've spent a heap of $$$ on an engine build and i'm happy to spend the extra dollars to buy sucrogen for a little while to be guaranteed the same octane/quality of fuel every time. in my opinion it's especially important during the testing/tuning phase otherwise it becomes another variable.
I'm sure spending this amount on fuel is going to sh*t me soon, but for now i just put it down to part of the expense of building a big hp motor.
Edited by tk80
And then you'll go back to the normal pump stuff once it's tuned/tested or you talking generally???
Confused :mellow:
I mean ye the Sucrogen stuff is great, but then so is the price. At least the owner was funny when he got on here and started abusing people. Good for a laugh.
Yes, i can see a time where i'll be buying pump e85. hopefully the consistency will improve as i've heard of a few bad batches from rozelle. Having said that, the tuner has told me as long as the octane is above 105 then the engine will be safe.
pump e85 is not much different, if at all to drum apart from the price... just saying.
have done back to back testing with both fuels. on dynos.. no difference. the ONLY time you may have an issue is if youre tuning e85 to the absolute limit. which you shouldnt be anyway
ah yes, that douche bag... i think all our cars should have blown up by now or something should have rusted through etc etc *insert scare tactic to justify drum price*...
must go down to United soon to check what E% their E85 is... i'm guessing it'll be around E90 like last time they had it pre-floods - even more powah! :D
Sorry for the off topic, but I'm curious how you all can be happy to pay so much for fuel, like I pay $1.60 a litre for bp 98 octane, you all pay over $2.50 per litre. Is it really worth it?
Oh I thought I read up further that it's $550 for a 200litre drum.
What's your economy like. I get 400-450km from 60litres.
Just had a look and the closest and only e85 servo is a caltex 50 km from home.
Edited by lilcrash
A lil off topic my car was tuned on caltex eflex just wondering if any of u boys notice a power difference from uniteds e85 and the caltex e85?
I have been filling at United for the last 3 tanks, its more expensive at 10c less than unleaded and then I need to put a little 98 in also to drop the ethanol percentage until I get a tune. It definitely smells better though. I will let you know when I get it back on the dyno.
It could have possibly saved your engine though, at 20c less than unleaded it works out to around the same price as 98 to run in my car.
385rwkw on eflex, 400rwkw on E85
eflex may have been mid 60's though at the time.
that's what i was thinking scotty, get some United and just drop in a little 98 if it's like E90 until i get a touch-up - just bring the laptop with me to get the E% reading
although, the wideband should richen things up to the target AFR's in normal cruising even if it's E90
Ye sorry you've sorta missed a "in" joke from a few years back.
Basically the owner of Sucrogen got on here being a ripe tawt, saying pump E85 is a waste of time.
So that you should buy "his" stuff as it's "so much better".
I mean no doubt it is, but at almost double the price of from the local bowser... Not really viable for anyone with a car that gets used regularly. Plus you then needed somewhere to store said drums...
Have a read if you want a laugh: Click Me
Didn't you get the display Daniel?
didn't see the need really... did the baseline E85 tune from a drum of Powerplus to get an exact baseline (which it was, bang on E85), did the 98 and that's it. I mean, i'm not going to change anything depending on the E%, Trent has set that all up and i ain't going to touch that. So constantly seeing the E% would be interesting purely from a curiosity point of view, but for me, not worth the $$ especially when i can just plug the laptop in if i really needed to know (which i will when i get some United)
In hind sight, what i should have done and what people should do if setting up flex fuel is to do the 98 tune and a baseline E100 tune. IMO that's obviously going to cover all the variants.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
