I run both Caltex and United on the same tune with no issues.
On the road the variation between the two would barely be noticeable. As long as you tune for the higher ethanol percentage the afr's will only become richer anyway.
  • Replies 71
Full flex tune baby :banana: haha
Make sure you earth the drum to the car (or whatever you're filling), static can be a nasty surprise when dealing with fuel. A jumper lead will work just fine.
well apparently the red plastic 20L bottles are better for e85 so that shouldnt be an issue
The difference between 70% (caltex) and e85 (united) will not be noticeable in terms of power and response.. Because there usually isn't any.. Only on mega boost levels will it make a difference.. The extra 15% is just a fudge factor
Flex tune is good :D
I'm secretly hoping someone will work out how to set up the Fcon Vpro with the new Haltech ethanol sensor, I heard it's only a couple of hundred... I will probably have to work it out myself as usual.
Does anyone have detailed information on them yet?
Probably not.. I just like it cause on long drives I can run pump without having to drain most of the ethenol :)
That was my plan, but I love E85 so much I hardly swap to pump 98 lol
You'll run pump if you have to drive to Albury or Brisbane like me haha
Haha I'll give it a go on the next trip to wakie and see what Milage I can get
I think a Servo at Albury and one at Yass would see me to Sydney fairly easily. A long range tank would be great though until then, it takes too long to fill with the jerries.
I will have 100L capacity soon, once the 20L poly surge tank goes in. Still not enough. :no:
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
