Hopefully not a repost..
http://www.youtube.com/watch?v=c2eBeAfY174&feature=related
Starts at about 4 min.
"Intrigued to say the least, he was just sleeping lol. Then woke to find windows covered and people shouting . Probably another crazy game show"
"My Wife just translated it for me.
The police noticed the car parked suspiciously, so they did a number plate check. The Number plate was reported stolen, so they took a look inside. The guy sleeping inside was identified as someone wanted (maybe for murder, but my wife wasn't sure). Supposedly he had a rep for being violent, so they performed the unusual ritual on the car while he was asleep."
Edited by Tomek
Reminded me of one of those Steve Erwin jobs where he wakes up a sleeping Crocodile just to jump on it and try and wrestle the thing into a truck..gotta admit this guy has some balls if not brains..
oh and why did the cops not just break into the boot or similar and disconnect the battery etc? im not much of a mechanic but surely there would be a way to disable the thing from the outside?
yeah that last minute or so was quite painful to watch, he must have been having a nice old slumber before being woken up by half of Tokyo's finest. wonder if the owner would bother getting it fixed or just throw it to the auction houses?
those cops are seriously retarded. even after all the stupid stop sticks and barriers and then a van and a bus he still nearly got away. they put the bus in front of him but the van was meters behind giving him a good run up which put his life and theirs in danger and if he'd been able to see which way to turn chances are he would ahve gotten out without a good launch in the right direction.
instead of fking about with all that crap all they had to do was put the van right on the rear bumper and the bus right on the front bumper then kick in the window and haul him out. but no, they'd much rather call in 20 cops, 5 vehicles and spend an hour or two pissing about.
I did like that typical japanese he's braking the law but still put his left indicator on to exit the curb... lol.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
