In the near future I'll be increasing the performance in the stag. I have been doing some research and people seem to think that the standard auto is not up for the extra power. I would like to know how people have fix this issue.
I am especially interested if any one has manage a auto to manual conversion? If so , what was involve and would they do any thing different? Your advice would be appreciated!
https://www.sau.com.au/forums/topic/377597-m35-transmission-options/
Since it's an M35, have you looked at the Shift Kit Jetwreck is offering?
There is no auto to manual conversion at the moment, but if you do a search you'll find out all the info. There is a lot of info on this.
Would be good to do a group investment on producing a manual conversion kit.....would benefit us all as making 1 off's is just not economical!.....e.g. would be good to draw up and product at least 3-4 bellhousing's at once
How much HP are you chasing...I am thinking the auto with the Transgo kit is good for about 300AWKW's!
Edited by Jetwreck
So is anyone doing the Shift Kit in Adelaide yet?
If you can take your car off the road for a couple of days and are capable of undoing a couple of bolts I can do the VB and send back to you!
Hmm, I am by no means a mechanic but should be able to "undo a couple of bolts". This is moving down my list now as I will probably be doing some body work due to a car park scrape.
However, I will PM you when I get ready, hopefully you will still be doing them then????
Did I read somewhere about $300 ?
Cheers
Jidge
Cheers
Jidge
about $245 for the kit depending on the exchange rate......and $250 for the fit out to your VB including shipping via TNT to and fro(metro areas...so up to $25 each way).
a total of $495.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
