Hi All,
I am about to buy a set of 19" Weds Kranze wheels. fronts are 19x9 +25 and the rears are 19x10 +20.
rears will be a solid fitment, Im just not sure about the fronts. Is the offset too high??
Anyone have pics of an ECR33 with a x9 +25 wheel fitted??
cheers.
https://www.sau.com.au/forums/topic/377623-19x9-25-fitment-on-a-ecr33/
19 x 9 +25 would be pretty flush with the front guards. You should only require minor lipping of the guards and to push the plastic liner and screws up a bit (or remove it), this is assuming 235 width tyres.
The 10 +20 would be outside the guards at the rear by a little bit (10mm) without some extra camber (~3° neg). But it would look fat.
From the plenty of pics I have seen the offset to guard flushness on the R33 GTST are pretty similar front to rear. Typically for the same offset you really only need 1/2" wider wheel on the rear - but obviously this depends on how much camber you have front and rear.
Edited by simpletool
