Some of these guys are running 160mph+ in street cars man...
i know this, supra forums vids n youtube r my best friend lol
they even do it in fullweight cars, 28x9 or 10.5 slick "with" IRS and H-pattern stock 6 speed box
alot of them were running the garrett gt47-88 but not alot are leaning towards the precision 7175 and 80mm range turbos
and thanks pj, were i get htis 6766 bolted up ill let the figures speak for themselves, i dont see why it wont make 700whp on conservative boost and e85
  • 9 months later...
my brother has a 62XX on his r34 GTR
made an easy 350kw on 98 with 20psi... we didnt push further on 98 as the bottom end is stock
currently sitting on 420kw with 21psi... this was with 65% ethanol in the tank... its up to 84% now so will be going back on the dyno and pumping another 5-8psi through it.. should crack 450kw quite comfortably. Turbo can definitely make 500kw on e85 but the motor is stock so I don't think its going to get pushed that far
in terms of response... from my personal experience I wouldn't exactly call it street friendly.
There is definitely lag... I don't see positive PSI until 3.5K ish RPM... compare that to my -9 where i've got 5psi by 2.5K ish....
Although once 4.5K RPM comes around all hell breaks loose... they pick up boost so quick so the power delivery is just one big rush...
its a mental setup... but if i was to do it on mine I'd go one size smaller so I could feel some boost during daily driving...
the cam gears still need to be adjusted so lag will come down a bit
Edited by usmair
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
