exactly as above. it appears that the rear of the cranks on these things are different between 2wd and 4wd. the spigot bush spec'd for a 2wd RB25 is too big to fit into the rear of the crank on my engine. the inside of it fits the gearbox fine. outside is at least 1mm or more too big.
what did you do for one? all the parts I come up with in FAST show the 2wd bush and that carries across almost every nissan engine I have found EXCEPT mine.
engine was built 09/97.
help!!
For my conversion (32 gtr box into S1 RS4) I used the spigot bush that came in this kit, theres no part number listed for the bush, but you could probably email him and find out what one it is.
http://www.kudosmotorsports.com/catalog/nissan-seal-kit-gearbox-genuine-nissan-skyline-r32-gts4-gtr-r33-gts4-gtr-r34-25gt4-rb20det-rb25de-rb26dett-inc-neo-p-548.html
worked it out :)
still have the auto bearing in place. it looked like it was part of the crank.
Lol, I was going to suggest that; but given your background, it seemed a little Captain Obvious.:whistling:
Thanks Chris; I feel a litle better knowing that...
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
