Nice.
Couple things. You forgot the right headlight. some tint would look nice. the driver front tire is too thin. that speed hole (hehehe) could use some work - shading is off. the driver side splitter doesnt seem to go under the bumper.
very secksy over all. ill have to mess with that. looks like fun.
https://www.sau.com.au/forums/topic/37769-modded-g35/#findComment-761170
Well spotted, agreed on front tyre and intake hole, splitter was a layer fault (me moving them around and not putting it back)......other headlight can't be done due to the light....there is actually a clear lense on the left one but you can't see it cause its in shadow :D
Thanks for the feedback though
https://www.sau.com.au/forums/topic/37769-modded-g35/#findComment-761464
