post-83703-0-27589200-1316437176_thumb.jpg HP Pavilion DV6-6102AX Laptop - NEW IN BOX, UNOPENED.
Pickup available in Sydney Metro area or will post at your expense.
$1200
RRP is $1598 so $400 saving on new one
Processor Type: Quad Core A8
Processor Speed (GHz): 2.50
Installed RAM (GB): 8
Hard Drive Size: 750GB
Screen Size: 15.6"
Operating System: Windows 7 Home Premium
1 Year Manufacturer's warranty. (Buyer's responsibility to arrange directly with HP).
Brand: HP
Model: Pavilion DV6-6102AX
Colour: Black
Features Battery Type: 6-cell Lithium Ion
Bluetooth Enabled: Yes
Digital Media Cards Reader: SD Memory Card, MMC
Hard Drive Speed (rpm): 5400
Graphics Card Brand: ATI
Graphics Card Memory (MB): 1GB
Graphics Card Memory Type: Dedicated
Graphics Card Type: Radeon HD 6750M
Included Accessories: AC adapter, User guide.
Networking: Ethernet 10/100
Optical Drive Format: DVD Burner
Optical Drive Type: Blu-ray ROM
Processor Brand: AMD
Processor Model: 3510MX
RAM Expandable To (GB): 8
RAM Configuration: 2 x 4GB
Ram Type: DDR3
USB Ports: 4
Disk Drives Hard Drive Size: 750GB
Screen Screen Definition: High Definition
Screen Resolution: 1366 x 768
Screen Size: 15.6"
Screen Type: LED
Audio Microphone: External
Speakers: Altec Lansing Speakers
Networking and Internet Wireless Networking: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Connections and Expansion Audio Ports: Headphone Jack, Microphone Jack
Video Ports: 1 x VGA, 1 x HDMI
Software and System Requirements Included Software: Cyberlink DVD Suite, Cyberlink Youcam, Omnifone, Adobe Flash Player, Adobe Shockwave Player, HP Setup, HP Wireless Assistant, HP Support Assistant, User Guide Documentation, HP ProtectSmart (HP 3D DriveGuard), HP Power, Adobe® Reader®, HP Cloud Drive, Windows® Live Essentials.
Dimensions Product Width (cm): 37.8
Product Depth (cm): 24.68
Product Height (cm): 3.11/3.52
Product Weight (kg): 2.54
Warranty Manufacturers (months): 12
Labour: 12
Parts: 12
Processor Processor Brand: AMD
Processor Model: 3530MX
Edited by rhysc1986
https://www.sau.com.au/forums/topic/377702-hp-pavilion-dv6-6102ax-laptop/
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
