post-83703-0-27589200-1316437176_thumb.jpg HP Pavilion DV6-6102AX Laptop - NEW IN BOX, UNOPENED.
Pickup available in Sydney Metro area or will post at your expense.
$1200
RRP is $1598 so $400 saving on new one
Processor Type: Quad Core A8
Processor Speed (GHz): 2.50
Installed RAM (GB): 8
Hard Drive Size: 750GB
Screen Size: 15.6"
Operating System: Windows 7 Home Premium
1 Year Manufacturer's warranty. (Buyer's responsibility to arrange directly with HP).
Brand: HP
Model: Pavilion DV6-6102AX
Colour: Black
Features Battery Type: 6-cell Lithium Ion
Bluetooth Enabled: Yes
Digital Media Cards Reader: SD Memory Card, MMC
Hard Drive Speed (rpm): 5400
Graphics Card Brand: ATI
Graphics Card Memory (MB): 1GB
Graphics Card Memory Type: Dedicated
Graphics Card Type: Radeon HD 6750M
Included Accessories: AC adapter, User guide.
Networking: Ethernet 10/100
Optical Drive Format: DVD Burner
Optical Drive Type: Blu-ray ROM
Processor Brand: AMD
Processor Model: 3510MX
RAM Expandable To (GB): 8
RAM Configuration: 2 x 4GB
Ram Type: DDR3
USB Ports: 4
Disk Drives Hard Drive Size: 750GB
Screen Screen Definition: High Definition
Screen Resolution: 1366 x 768
Screen Size: 15.6"
Screen Type: LED
Audio Microphone: External
Speakers: Altec Lansing Speakers
Networking and Internet Wireless Networking: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Connections and Expansion Audio Ports: Headphone Jack, Microphone Jack
Video Ports: 1 x VGA, 1 x HDMI
Software and System Requirements Included Software: Cyberlink DVD Suite, Cyberlink Youcam, Omnifone, Adobe Flash Player, Adobe Shockwave Player, HP Setup, HP Wireless Assistant, HP Support Assistant, User Guide Documentation, HP ProtectSmart (HP 3D DriveGuard), HP Power, Adobe® Reader®, HP Cloud Drive, Windows® Live Essentials.
Dimensions Product Width (cm): 37.8
Product Depth (cm): 24.68
Product Height (cm): 3.11/3.52
Product Weight (kg): 2.54
Warranty Manufacturers (months): 12
Labour: 12
Parts: 12
Processor Processor Brand: AMD
Processor Model: 3530MX
Edited by rhysc1986
https://www.sau.com.au/forums/topic/377702-hp-pavilion-dv6-6102ax-laptop/
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
