highly unlikely country BPs will have 98
dont use octance booster, it does an awesome job of f**king spark plugs and o2 sensors real quick, probably not great for the fuel system either.
just use 91 and dont thrash it if your that worried, if everything is working properly with a standard ecu theres no way you'll make it knock just cruising along if you use 91.
Yeah not worried for when I get into Gero, I get free fuel once I'm there ;)
Thanks for everyones replies, I'll just take some octane booster for the trip, I'll try do some re search on octane booster and o2 sensors to see if they do mess them up.
Jeremy
E39 528i, 100kmh, 6.6L/100km AC + radio on., theoretical full tank economy of 1060km worship.gif
Martin, my old 32 (one over east) could get 650+km/tank sitting at 100 solid and that was fairly powerful... Something not right with your car....
Something not right with my car lol, give me a break I'm new to tuning! :P I get 600kms to a tank with my daily driving habits, that's better than most... I just haven't figured out the right mixtures for the higher load/RPM cells yet, if I go much leaner than it's set at now (around 14.7 - 13.8) then the car starts to surge. Also the transient throttle enrichment goes a bit off when I make it leaner, so for now I've left it where it is. I have a feeling Andy didn't set my injector latency up quite right when he tuned my car, so it messes with the target AFR's a bit. I don't want to adjust it though cos it will throw out my high load/RPM cells and I don't wanna tune them on the street confused.gif
1 bottle over 2 tanks of fuel is enough to completely f**k a brand new set of plugs, seen it happen several times. dont use it
This.
Octane booster is shit, stay away from it. Just run the 91 as Jonno said, it will be fine on the stock ECU as long as you're driving gently.
unless there's something seriously wrong with your car, you'll make it on one tank.
just feather the throttle slowly going up hills instead of flooring and you'll be fine.
I drove to geraldton in june (via coast rd).
If i can make it from duncraig > geraldton on one tank (60L) with a carb that hasnt been kitted from new, no injector cut off on decel/ o2 sensors etc then you should be fine or your car has problems.
Yeah, my Line is tempermental
Socrates I never knew you lived so close to me.
Cheers for the feathering advice haha, I'll need it.
I made several trips to Albany back & forth this year (around 430 km one way) & the best I can muster is around 10.5L/100km, then again I'm usually the one overtaking people which means foot down 100% while this is happening.
EDIT: I bring a 10L fuel can everytime I go, just in case.
Edited by Mayuri Krab
I drove to Kalbarri recently and all the BP's i stopped at had 98.. i didn't have any troubles at all.
I'd recommend you stop at the caltex outside Dongara for a pie as well... they are awesome pies!
Cheers man this gives me a glimpse of hope, and yes I know, those pies are amazing!
I'm looking rather forward to free crays in gero tho ;)
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
