Hey all so i was talking to this guy at work who is a car nutter (like 40 lives at home with his dad and spends all his money doing up one of his 10 commodores haha)
so anyway he also has a datto 1600 and a 1984? Bluebird, and this is where my question lies.
Apparently the Bluebird is running a 2L datsun engine (not sure which one) with a custom turbo setup consisting of carburetor to turbo to throttle boddy, and at first I'm like wtf is that even possible and then he explains it to me (most of which i didnt understand) and how it doesn't run and intercooler and some other shit.
car makes 184HP at the wheels on 8psi
so anyway when i get home I inform my dad who is also quite experienced with cars, although Im willing to say probably not as much as this guy. But my dad says its not possible....ARGUMENT BREAKS OUT..so on so on hahaha.
Can anyone confirm this please so i can settle it once and for all?
Ill try get pics (he had them on his phone to show me)
Cheers :)
https://www.sau.com.au/forums/topic/377712-carburetor-running-turbo-engine/
  • Replies 47
yes this is possible, from what i understand from what you've said, he's running a in a draw through configuation
Thanks very much, any chance you or anyone can explain this a little more?
also cheers socrates for your input.
yes def possible, draw thru is the way to go. and turbo's have been around longer than every day fuel injection.
my bro used to have a kombi with a setup like this. only issue you have with a draw thru is that your pulling your fuel mixture thru the turbo itself, which can make it a small pain to get tuned and running right. my brother kombi had an SU carby infront of it, seemed to give tyhe most progressive flow.
in your post you speak of a throttle body aswell?? that doesnt need to be there, as the carby is the throttle body in these setups.
Turbo sucks air through the carby. Turbos need to be built with different gaskets - ones which won't break down when they get fuel on them.
Apart from that it's cake. Strombergs are one of the most popular carbies to use but webers are good too, as the above pic shows.
Wow thanks so much guys....this is why i love SAU haha
one more thing, can someone explain how the fuel doesnt explode from the heat generated by the turbo?
Edited by RBert
Not enough pressure and no source of ignition, ie. spark.
Cylinder pressure is up around 150+psi, where as a turbo may be producing 25psi between the turbo and inlet. And fuel doesn't ignite well without a direct source of ignition. Drop a lit cigarette into fuel and it's not likely to ignite.
Edited by Cowboy1600
As above, fuel has a fairly high spontaneous combustion point(with source of ignition), and the heat of the turbo just isn't hot enough on the inlet side.
The fuel actually helps to cool the inlet down by using the heat in the air to vaporise, in a way similar to water injection.
everything above is correct. there have been various cars over the years running carby turbo setups. in fact there was even a turbo VB commodore (unsure whether it was a holden thing or just a thing done by a few dealers). very rare. a mate of mine actually has one of the setups tucked away in his cupboard.
Oh, and your mates car would be an L20B which is a very, very popular engine to do suck through set ups on. They are tough motors. Although for racing applications many people use L18s as they rev harder. You can bore them out to nearly 2L (bore and stroke can go past this but you lose some revs). Again, incredibly tough motors.
I've owned 1600s and 180bs with either L18s or L20bs (and one Z18et which is an L18 bottom end with a twin spark head, EFI and turbo) and if you saw the sheer destruction I tried to force upon them you would be horrified. Simply horrified.
Off topic
Would a Z18ET head bolt directly onto an L20 bottom end with no mods? Sounds tempting.
Definately have a soft spot for the L series engines. Indestructable. Mine has done roughly ~300,000k, odometer stopped at 250,000km - Always gets a flogging when it's driven, but oil is changed every 5000km with out fail - all original parts.
Currently my Bluebird's stock head is off being reconditioned and mechanically cleaned, so much carbon gets caked onto the exhaust ports - it's crazy.
Only reason for the head coming off is because one of the head bolts snapped, but lucky no blown headgasket. Just doing the cleaning and reconditioning due to all the effort taking the head off.
It will, but manifolds are different. They are a crossflow head.
Try and get your hands on an A87 head off an L18. They are the high comp, big port heads and get L20s singing up to 1000rpm harder than stock.
Failing finding an A87, the W53 is next best option.
I had an A87 and a factory EFI head (and complete set up_ in my shed until late last year. In fact I think the guy who bough the EFI stuff off me is selling it again. Check Ozdat
a BLOW THRU carby set up has been used many times over the years, its a matter of sealing the carb up so it doesnt leak boost. . . .no fuel in the turbo that way . . .as for the L series L20B, lots of mods are easy to do on these motors including stroking using Z series parts :thumbsup:
on the L20 discussion, my mechanic mate had a L20 in a 1600. it was bored and stroked. made about 155hp at the wheels (still natro) from memory. only problem was that it kept arcing out headgaskets because of how bored out it was (gasket was too thin between cylinders).
That's great mate, but we're talking suck through.
Z24 cranks stroke them out to 2.4L and they go like hell. But it requires a fair bit of work to get a Z crank to fit an L series.
The world needs more angry Ford 2.0 pinto's and L20s etc imo
and im a Big engine nutter
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
