Hey Guys,
Selling out all my R32 GTR interior parts, Most item's listed below..
If you are after something that isn't below, PM or post, as I probably have it, especially the little items.
Please excuse my error's in describing the parts, i'm sure the photo's will speak for themselves.
I am also going to sell my front and rear seats, EOI atm, will get some pictures up soon. They in good condition.
All parts are in good nick, considering their age. If anything they probably just need a really good clean....
Inspections are welcome.
All prices are negotiable, so hit me up with an offer...
Can ship some item's interstate, buyer pays postage.
Front Door Trims:
$80 each, or both for $150
Rear Trims:
$50 each, or both for $80
Roof Lining:
$100
Sun Visors:
$20 each
Glove Box (GTR)
$60
Centre Console Surround:
$50
Centre Console red included :)
$50
Kick Panels:
$20 each
A Pillar Trims:
$30 each
Steering Column Surround:
All for $50
Lower Trim:
$30
Rear Boot Carpet:
$40
Rear Boot Trim:
$30
Parcel Shelf Trim:
$40
Carpet:
$100
Interior Lights:
$20 each
Front Speakers & Mount:
$50 (pair)
Rear Wiper Motor:
$50
3 Guage DIN Panel:
$80
Climate Control Panel:
$100
Window Control:
Driver - $80
Passenger - $30
Rockford Fosgate Sub 12"
$80
Clarion Sub & Kenwood Amp:
$100
Front GTR Seats (EOI ATM)
Drivers & Passengers - EOI
Rear GTR Seats
$100
A/C System:
Compressor - $80
Condenser - $50
Electric Fan - $50
Evaporator - $80
Blower Motor - $80
A/C Lines - $80 set (1 line a little damaged)
https://www.sau.com.au/forums/topic/377729-r32-gtr-interior/
hey im keen on gtr front driver seat...
ATM i will only sell as a pair, because i will never be able to sell the passenger seat on its own.
Dont be rude to your passengers! :( J/K
I'd be interested in the centre console surround, drivers side A pillar and front speaker mounts if you would be interested in bundling and posting them...
PM Sent
Hey Mate
Got a working digital clock?
PM sent
EDIT: WillL, your inbox must be full, unable to PM
I have the clock, works fine.
what's your location?
Edited by GreddyGo
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
