Whats the piping diametre?
Edit: only reason I ask is because if it's for a GTT i assume it'll be >=3", which will give you crappy back pressure. Less performance etc.
You're best off looking at a 2.5". If you're located around the northmead area I know a guy who can go a little cheaper than Castle Hill Exhaust.
Edited by SKITTLES
if it's 3" it will be loud. turbo's act a bit like a muffler so that means that a 3" exhaust on a turbo car will be much quieter than on a non turbo.
also being 3" you may find a loss in low end power as 3" is much too big for a small displacement engine.
+1 to custom.
I would think that 2in would be fine for RB25DE as my L24S is 0.1 of a L smaller.
Or have i gone too small?, or carburettored vs EFI should have different size exhausts?
I think a RB25DE (my r34 gt) had a 2.25" exhaust from factory - correct me if im wrong but from when i was searching around on threads on exhaust thats what i found if i can remember.
My 33 has a 2.5" cat forward then after the cat it narrows down to about 1.8". Turbo exhausts are 2.5" from factory and GTR exhausts are 3" I think. If this is the case I've been thinking about swapping in a factory Turbo Exhaust.
yeah stock turbos are 2.5" and they are a good option to put on. good flow with good mufflers.
+1 to custom.
Socs.. lol.
RB25DE R34 makes 200 @ fly.
L24s (a long time ago) 125hp @ fly...
2.5" is good for NA skylines..
Got a 2.5" catback on sisters S13 and it made 105rwhp through an auto box. - 235kms.
Socs.. lol.
and the missus SSS (which makes about 10kw less at the fly than a S13) makes about 115hp at the wheels with a 2" exhaust.
As i said i just installed 3" Fujitsubo legalis r catback exhaust on my r34 gt and it absolutely sounds deeper and quieter. The previous exhaust was 2.25" custom catback and was louder and crappy. i think it depends on what brand it is so custom exhaust can have a lot more various sounds. anyway thank you very much for ur recommandation! but i could not give up the name and its value FUJITSUBO haha.
Edited by crocophk
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
